Hey guys,
To make sure the day runs nice and smooth just like every other one, I want to get a list going of who's able to help out with what on the day in advance for each Texi from here on.
Let me also say, without the help of the people who volunteer each day, no club events would happen, so each of you who help out are GREATLY appreciated :)
Roles;
Morning starters x 2
Morning timers x 2: Nim
Morning to go whoa starter: Sloane
Morning go to whoa
BBQ Cook: Olivia
BBQ Money: Anna
Afternoon timers x 2: Nim + Sloane
Of course drinks and food are provided free of charge throughout the day and a seat/stopwatch etc depending on the role aswel as a fluro vest. Dont be afraid if you've never done it before, I will be right there and if anything needs to be asked I'll be able to give an answer straight away and show how to do it etc
Cheers :)
https://www.sau.com.au/forums/topic/366555-texi-officials/
Hey mate. We will be there bright and early like last time, can help with cone setup ect. My girlfriend Olivia helped out and stuff with the canteen ect and driver sign up so im sure she will have no dramas in lending a hand again. Shall see you there :)
https://www.sau.com.au/forums/topic/366555-texi-officials/#findComment-5847323
Luke if you can help out early that's great, as you know getting the courses ready has to happen quickly so they can be tested before drivers brief. If you can help out with getting cones to the skidpan out of the ute that would be ace!
Last time we got lucky and Ben used the ute to drive around and push them out but that's not always available eg when its attached to the trailer haha!!!
https://www.sau.com.au/forums/topic/366555-texi-officials/#findComment-5851099
Yah no problems ill be there hopefully 7am sharp. Ill already have my stockies on my car so ill just need to get checked and thats it. Yah help with cones no problems the ute was fun and easy last time lol. My GF only lives at Doonside so we are like 10min away so the early start should be sweet. Oh also if anyone happens to have any probs ill have some tools with me including multimeter and usuall spanners ect. And my workshop is only in blacktown for anything else major :)
https://www.sau.com.au/forums/topic/366555-texi-officials/#findComment-5859237
Terry is there any role you'd like to choose? Or just whatever?
Anywhere I'm required eg morning timer?
Got the 7 radios (+ headsets + backup batteries) today, that Matt had arranged.
Just need to give you a 2min rundown on how fragile the connection is between the headset and the radio.
https://www.sau.com.au/forums/topic/366555-texi-officials/#findComment-5859671
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
    • No. The mark is with respect to the cam rotation. None of those things have altered it. When stationary, the cam position stays in sync with the crank position. It doesn't matter if you moved the head 4 feet up. Hence, that mark needs to stay exactly where it is.
    • Toasty! I was around the same. Around 50 but with a fuel cooler. Got my tuner to dial down the pumps and its so much better.. i think last time I drove it was around 35-40 during summer. PWM makes a huge diff. I have the 1 PWM controller running my feeds.
    • Driving around town in summer, probably like 50°C tops. Went for a 2 hour drive before in summer, somewhere in the 60°C Mind you, I have 3x fuel pumps. 2x 460L 1x DW200
    • Good advice, I’ll try that.  and yeah i thought 5 degrees was a lot as well. The gates T291RB timing belt that was recommended for this engine was kinda tight when installing it and with both cams inline with the timing marks, the belt teeth wouldn’t line up with the gear. So I just turned the whole exhaust cam gear like half a tooth so the belt would go on and then adjusted the cam back inline with the timing mark, so some of that 5 degrees is from that. The actual cam has probably only changed about 2-3 degrees if that makes any sense lol also wouldn’t stuff like decking material from the block, head and different thickness of headgasket and the fact that it’s a rb30 bottom end affect the accuracy of the original timing marks?
