Hi all,
I'm hoping someone can help me out.
I'm doing some upgrades on a mates R32. It's an Rb20 and have done some mods to it.
Basic Mod list;
- GT3071, .63 rear housing external gate.
- Tial 32mm gate
- Turbosmart FPR800 fuel reg
- Turbosmart Dual port BOV
I made the following stuff for it;
- Custom exhaust manifold, top mount. Using 32mm steam pipe.
- Custom 3.5" dump with 2" screamer into 3" system with metal cat.
- 3L surge tank with an 044 pump.
- Also made some intercooler piping for the bay to accommodate the top mount manifold.
My question is, what size injectors do you guys recommend?
I was thinking about some Seimens 600cc, Or should I step it up to 800cc. As soon as this motor pops, an RB25 is going in, with a fabricated inlet manifold. I was planning on getting some fuel rail extruding and making a fuel rail for it as well.
Also, is the RB25 injector spacing the same as the RB20? ie, can I use an RB25 fuel rail, or is the spacinf different?
Thanks in advance.
Tark
https://www.sau.com.au/forums/topic/366568-rb20-3071-upgrade/
they would be enough, but could it be more beneficial to get bigger ones to have some headroom for future upgrades or E85 fuels etc..I mean its better to have under worked rather than overworked injector isnt it ?. Plus I beleive the siemens have been getting a good rap and are fairly well priced to.
Ye true, depends if he is going to change turbo or not really.
600cc would be more than enough for a 3071 on E85 - loads of room!
But 440's will be enough for a 3071 on PULP either way.
Depends on budget. GTR injectors - $150 for a set is a darn sight more affordable than 600's :)
Just comes down to what you want to do. You can always sell the GTR ones off later and buy 600's if you need.
I see they are cheap..
When i was looking for injectors i was told to get the 480 s15 ones but i couldnt find any for less than 400 a set so when i found 650s for the same price figured may as well go bigger. stupid sidefeeds
But yeah if you can get them for 150 you have nothing to lose and plenty to save :yes:
It depends on what fuel your running and power goals for the planned 25.
Either way if you get gtr injectors and need bigger later you can always sell them as there are always people wanting them. Just make sure you get them cleaned first :thumbsup: .
I would go for some 600cc injectors if there not to expensive compared to GTR injectors, they should be big enough even on E85.
Thanks for the replies guys, much appreciated!
We don't have a specific hp goal. It's more just put the right components together with the right tune (I forgot to add, I'm putting a Vipec ECU into it.) and be happy with what it's got sort of thing. Having said that, I'd be expecting around 330-350rwhp, on around 18psi.
I think I'll grab the 600cc injectors. Would rather get new injectors and know they are right.
Is the injector spacing different between the RB20 and the Rb25? (In reference to the Fuel rail.)
Just wondering if I can mod the mounting of an RB25 aftermarket rail, or I'll just make my own.
Cheers
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
