Finally received my Top Secret full intake kit (thanks to Henry at RMSMotorparts who sources all my JDM stuff)
Got my Zele skirts too but there's plenty of pics of those floating around
.... the Top Secret intake and turbo inlet pipes not so much
Intake pipes are 65mm going into 60mm turbo inlet pipes
I've downloaded a few diy's for the inlet pipes and it looks like a knuckle buster, not looking forward to it
https://www.sau.com.au/forums/topic/366586-some-top-secret-goodies/
agreed, always been a fan of Smokey's cars
my build will be solely Top Secret engine side - intake, ti intercooler piping, high flowed oem turbos......
Nice!
Looking forward to see the results.
Big respect to Smokey Nagata along with other big garage names ie: Mine's / MCR / HKS, just to name a few.
yeh the filters are from HKS but the cf makeshift airbox is TS's own work
most of the aftermarket inlet pipes end up looking all pretty much the same
Yes it was more my point that Top Secret have be re-branding HKS parts for years (same as Mines).
It's a great upgrade and one of the biggest restrictions on the earlier GTR so hope you have a nice tune to match for maximum gain.
You name by any chance isn't James is it? Can't wait to see the titanium I/C pipework.
Cheers
Marty
no not James
i dont mind if they are re-branded, the TS were a good 250 bucks cheaper than the HKS kit with their drop-in filters (which im running atm)
makes sense now then why they're using the hks filters
Martin has provided me an e-map for the intakes + midpipe, but i have a full 90mm ti exhaust setup in the air atm, so ill have to do some datalogging and get a new map done
i have to learn how to use the datalogger on the cobb
Edited by domino_z
installed intakes today, fit of the airbox and piping was spot on
have gained some welcome turbo spool and some bov sound letting off at high boost - will be alot of fun on cold nights up in the hills, well worth the price imo, and the cf shroud around the pod filters should provide some level of heat soak resistance stuck in traffic
seriously considering some gfb hybrid bovs now to get some more bov sound at high boost
Edited by domino_z
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
