  • Replies 65
Done. Also replaced the pump with one we new worked. Still no love.
Relays have also been replaced.
Can they pull the error code with a Consult 2 or 3, or attempt the code reading procedure & count the blinks?
C1206 via a Launch X431
A quick google of C1206 seems to suggest its an ABS code; whether or not thats actually a fault in the ATESSA system then I'm not so sure.
Regarding headlights; I personally take the front bar off and then take the entire assembly out - but my hands arent exactly small and dexterous :P
Confused.
C1206 is not a Nissan error code (they start with P).
If it is P1206, that points to an error in "Injector Cycle Cylinder #6"
Have a look at this site for Nissan error codes
http://www.permoveo.ltd.uk/tabid/122/OBD-Error-Code/p1206/Diagnostics/Nissan/Default.aspx
Still doesn't explain why the 4WD light is on.
The Synchro switch isn't pressed it is? (Silly question I know...)
C1206 is a Ford code
Headlights, just dive in from the back.
Edited by iamhe77
I thought you may say that...
The car is fitted with HID's and they seem to give of a pink light...
LOL @ pink light...maybe its aftermarket globes...
My 4WD light comes on intermittently too...I'm going to have to bleed/flush and do all the checks and find out WTF is it doing...
Na, you can see the bulb behind the reflector and inside the globe is a rod instead of a normal wire...
Ok I'll check it out.
Got the car back to Adelaide with the light on, we replaced what we could mechanically so what ever the problem is it's electrical...
How do I do a diagnostic check? Where is the blinking light? I assume on the ECU it's self?
Cheers.
Mike.
I thought you had tiny girl hands? Aren't you still in Sri Lanka anyway?
Mike, have a search through tthe forums, I've seen that a few times, and check out m35stagea.info, might be on there. I know there is a huge listing to all the fault codes and the procedure.
Other than that how's the car?
Cheers.
Mike.
Have a read of this thread as it has lots of information on the fault codes.
The light that flashes is the one of the engine on your dash.
Cheers
Andy
Mike, have a search through the forums, I've seen that a few times, and check out m35stagea.info, might be on there. I know there is a huge listing to all the fault codes and the procedure.
Thanks for the tips, i would normally check m35info but the page does not work on iPads, cant even login.
Car is great, no real issues as yet...
Spent all day removing the aftermarket DVD/Sat Nav/Monitor and ALL the wiring that went with it:
Then moved over to the drivers side where i found some wires which seem to lead to know where and others which i am having some trouble identifying what they are and why they are there...
These two parts were under the drivers side dash, 1 marked with Nissan and the other blank, not sure if they are standard or a factory upgrade.
This was not plugged into anything, found under the dash with a random wire spliced in:
wired back to this (it wires into a relay which is plugged into the harness which attaches to the seat belt and the air bag sensor):
This is another aftermarket feature, it seems to be wired into a stock location but the switch is not standard, my thoughts are that the driving lights were put in after and they couldn't be bothered getting the standard switch:
Also found this button which seems to do nothing:
I can't help you with all the funny stuff going on with your wiring, but the button in the last pic is used to make the mirrors fold in when you lock the car / arm the alarm with the button on your key. This works in addition to the switch on the LHS of the steering wheel which you use to manually fold the mirrors in.
Cheers, Leon.
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
