  • Replies 65
Done. Also replaced the pump with one we new worked. Still no love.
Relays have also been replaced.
Can they pull the error code with a Consult 2 or 3, or attempt the code reading procedure & count the blinks?
C1206 via a Launch X431
A quick google of C1206 seems to suggest its an ABS code; whether or not thats actually a fault in the ATESSA system then I'm not so sure.
Regarding headlights; I personally take the front bar off and then take the entire assembly out - but my hands arent exactly small and dexterous :P
Confused.
C1206 is not a Nissan error code (they start with P).
If it is P1206, that points to an error in "Injector Cycle Cylinder #6"
Have a look at this site for Nissan error codes
http://www.permoveo.ltd.uk/tabid/122/OBD-Error-Code/p1206/Diagnostics/Nissan/Default.aspx
Still doesn't explain why the 4WD light is on.
The Synchro switch isn't pressed it is? (Silly question I know...)
C1206 is a Ford code
Headlights, just dive in from the back.
Edited by iamhe77
I thought you may say that...
The car is fitted with HID's and they seem to give of a pink light...
LOL @ pink light...maybe its aftermarket globes...
My 4WD light comes on intermittently too...I'm going to have to bleed/flush and do all the checks and find out WTF is it doing...
Na, you can see the bulb behind the reflector and inside the globe is a rod instead of a normal wire...
Ok I'll check it out.
Got the car back to Adelaide with the light on, we replaced what we could mechanically so what ever the problem is it's electrical...
How do I do a diagnostic check? Where is the blinking light? I assume on the ECU it's self?
Cheers.
Mike.
I thought you had tiny girl hands? Aren't you still in Sri Lanka anyway?
Mike, have a search through tthe forums, I've seen that a few times, and check out m35stagea.info, might be on there. I know there is a huge listing to all the fault codes and the procedure.
Other than that how's the car?
Cheers.
Mike.
Have a read of this thread as it has lots of information on the fault codes.
The light that flashes is the one of the engine on your dash.
Cheers
Andy
Mike, have a search through the forums, I've seen that a few times, and check out m35stagea.info, might be on there. I know there is a huge listing to all the fault codes and the procedure.
Thanks for the tips, i would normally check m35info but the page does not work on iPads, cant even login.
Car is great, no real issues as yet...
Spent all day removing the aftermarket DVD/Sat Nav/Monitor and ALL the wiring that went with it:
Then moved over to the drivers side where i found some wires which seem to lead to know where and others which i am having some trouble identifying what they are and why they are there...
These two parts were under the drivers side dash, 1 marked with Nissan and the other blank, not sure if they are standard or a factory upgrade.
This was not plugged into anything, found under the dash with a random wire spliced in:
wired back to this (it wires into a relay which is plugged into the harness which attaches to the seat belt and the air bag sensor):
This is another aftermarket feature, it seems to be wired into a stock location but the switch is not standard, my thoughts are that the driving lights were put in after and they couldn't be bothered getting the standard switch:
Also found this button which seems to do nothing:
I can't help you with all the funny stuff going on with your wiring, but the button in the last pic is used to make the mirrors fold in when you lock the car / arm the alarm with the button on your key. This works in addition to the switch on the LHS of the steering wheel which you use to manually fold the mirrors in.
Cheers, Leon.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
    • Is there an actual website thingie for peoples who don't have Facebooks? Cheers
    • All Jap Day is coming up again! 13th of July this year. Are you going? Tickets go on sale on Wednesday 6pm. Please let Quang know as well. https://m.facebook.com/photo.php?fbid=1163155775853542   I still get shit from my wife for this photo because it is the happiest she has ever seen me. And it's not with her, it's in someone else's car.   Quang's EVO is sick, but that rotary wagon flying past was absolutely bonkers.
