  • Replies 65
Done. Also replaced the pump with one we new worked. Still no love.
Relays have also been replaced.
Can they pull the error code with a Consult 2 or 3, or attempt the code reading procedure & count the blinks?
C1206 via a Launch X431
A quick google of C1206 seems to suggest its an ABS code; whether or not thats actually a fault in the ATESSA system then I'm not so sure.
Regarding headlights; I personally take the front bar off and then take the entire assembly out - but my hands arent exactly small and dexterous :P
Confused.
C1206 is not a Nissan error code (they start with P).
If it is P1206, that points to an error in "Injector Cycle Cylinder #6"
Have a look at this site for Nissan error codes
http://www.permoveo.ltd.uk/tabid/122/OBD-Error-Code/p1206/Diagnostics/Nissan/Default.aspx
Still doesn't explain why the 4WD light is on.
The Synchro switch isn't pressed it is? (Silly question I know...)
C1206 is a Ford code
Headlights, just dive in from the back.
Edited by iamhe77
I thought you may say that...
The car is fitted with HID's and they seem to give of a pink light...
LOL @ pink light...maybe its aftermarket globes...
My 4WD light comes on intermittently too...I'm going to have to bleed/flush and do all the checks and find out WTF is it doing...
Na, you can see the bulb behind the reflector and inside the globe is a rod instead of a normal wire...
Ok I'll check it out.
Got the car back to Adelaide with the light on, we replaced what we could mechanically so what ever the problem is it's electrical...
How do I do a diagnostic check? Where is the blinking light? I assume on the ECU it's self?
Cheers.
Mike.
I thought you had tiny girl hands? Aren't you still in Sri Lanka anyway?
Mike, have a search through tthe forums, I've seen that a few times, and check out m35stagea.info, might be on there. I know there is a huge listing to all the fault codes and the procedure.
Other than that how's the car?
Cheers.
Mike.
Have a read of this thread as it has lots of information on the fault codes.
The light that flashes is the one of the engine on your dash.
Cheers
Andy
Mike, have a search through the forums, I've seen that a few times, and check out m35stagea.info, might be on there. I know there is a huge listing to all the fault codes and the procedure.
Thanks for the tips, i would normally check m35info but the page does not work on iPads, cant even login.
Car is great, no real issues as yet...
Spent all day removing the aftermarket DVD/Sat Nav/Monitor and ALL the wiring that went with it:
Then moved over to the drivers side where i found some wires which seem to lead to know where and others which i am having some trouble identifying what they are and why they are there...
These two parts were under the drivers side dash, 1 marked with Nissan and the other blank, not sure if they are standard or a factory upgrade.
This was not plugged into anything, found under the dash with a random wire spliced in:
wired back to this (it wires into a relay which is plugged into the harness which attaches to the seat belt and the air bag sensor):
This is another aftermarket feature, it seems to be wired into a stock location but the switch is not standard, my thoughts are that the driving lights were put in after and they couldn't be bothered getting the standard switch:
Also found this button which seems to do nothing:
I can't help you with all the funny stuff going on with your wiring, but the button in the last pic is used to make the mirrors fold in when you lock the car / arm the alarm with the button on your key. This works in addition to the switch on the LHS of the steering wheel which you use to manually fold the mirrors in.
Cheers, Leon.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
