Have a read of this thread as it has lots of information on the fault codes.
The light that flashes is the one of the engine on your dash.
Cheers
Andy
Hey Andy,
Gave that a crack and just got 0000, so back to square one as to why the light is on.
On another note the torque split gauge just reads zero all the time?
Cheers.
  • Replies 65
My torque split gauge reads zero 90% of the time.
Lock the diffs by pushing the button to the upper right of the shifter. It should now show around 10 on the gauge, and you'll have a picture of your axles and a cog with S (?) in the middle lit up on your dash.
That's all working from memory. Give it a go and see.
Gauge still doesn't move, just sits there at zero. Even from a standing start and nailing it which you would think would activate the gauge doesn't. It does engage the front wheels as there is no loss of traction but I'm unsure if it's just running all the time or working as per norml. Also not sure if the gauge it's self is also faulty, will have to trace the wires back and see.
Have you tried starting the car and putting it in drive straight away then stalling it? It should get rid of the 4WD light.....you may just have air in the lines.
I have not, do you mean stall the motor or stall it up as in foot on brake and gas? Sorry if that sounds stupid. Lol.
my 4WD light just came on too.. tho next time i started the car it was gone.. seems to be all ok though.. my Torque Guage reads 0 all the time too unless i nail it in the wet then starts reading as it should.. (tho never tried when the 4WD light is on)..
This thread still being worked on?
BTW i took out my sat nav dvd out too.. though i reckon i had more wiring than you! had to take out the passenger seat to get to it all :)
It always makes me wonder what they were thinking when they do things like that... LOL
I has 2WD... :ninja:
And it's raining... :whistling:
Finally think we've worked out that the issue with Mike's car is the ATTESA relay under the airbox (shut up Brad :P).
His relay is causing a 4WD fault light on my car, so that gives us a pretty good idea, but will know for sure when he sticks my relay in his car. :cheers:
WOOP WOOP!!! :banana: :banana: :banana: :banana: :banana:
Edited by impul535w
So was it the ETS realy in the end? And what does shut up Brad mean? :ninja:
So does this mean its an easy option for 2wd its still raining might have to pull the fuse and go for a spin
Im still skeptical about pulling the fuse, particularly after I saw the other Duncan write this
that gearbox/transfer case and mounting looks the same as r series. which means you are damaging your transfer case clutches running in RWD only. Plenty of people have done the "seems ok I'll drive like this for a while" thing.
the clutch packs have preload, and they will be slipping and wearing like bastards with the attessa pump off.
dropping the front driveshaft is fine though.
I won't be putting heaps of K's on, hoping that once Mike has worked it out, I'll get mine back this week.
Since mine is currently locked up at an alarm installers and can't come out to play, timing works out well :(
And Brad, I got your smug SMS, making us look at the front fuse and all :P
  • 1 month later...
I have the same intermittent issue of 4wd light.
anyone got pics of what the relay looks like
heres a reference to another 4wd light issue.
http://www.skylinesaustralia.com/forums/topic/294910-m35-stagea-4wd-light-on/page__p__5201550__hl__4wd+light__fromsearch__1#entry5201550
ok ...so today we checked ets relay and it working.... but it is not getting any signal as far as we can tell..... we put power through the relay and the pump fired up.... so it would seem the problem is upstream of the relay... any ideas would be greatly appreciated.. could it be a problem with the controller? or is there something more obvious??
How did you put power through the relay? Did you power up the coil or just put 12v on the output of the relay to turn the motor on? You could of just got the wire that goes to the motor from it. You should have 12v on pin 3 when ign is on. And there will always be 12V on pin 1 the bigger wire. Did you here the relay click.
The negative of the coil comes from the EITS C/U. The relay is grounded when it needs to be through the control unit.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
