I've been searching for a Jatco RE5RO1A for ages, and have never been able to find one for sale.
Are they that rare?
There are plenty of the 4 speed RE4RO1A models around...
Currently, I have a Jatco 4N71B (VL 4 speed auto) matched to my RB25det, and I really want to upgrade to the 5 speed auto.
If anyone knows of a place I might be able to ask about getting one, could you please let me know. Thanks.
https://www.sau.com.au/forums/topic/366601-5-speed-auto-in-r32-and-r33/
I think you'll find it's the same as V35, M35 Stagea, and late model Patrols. The latter two obviously have a transfer case.
Happy to be proven wrong, but I'm fairly sure that's it.
hi ive been told that the 5 speed auto came in the non turbo 32s and as the trans housingis the same size as the 4 speed the internals are smaller(read weaker) so that the whole lot would fit in
  • 1 month later...
in theory, could I buy this, rebuild it with stronger parts, and fit it to my RB25det?
http://www.nengun.co.../item/x36960207
Aftermarket ECU to run it?
. so you you want to pull a recon trans apart so you can fit stronger parts?your keen with deep pockets that for sure, i know info is limited but you might want to investigate this 5 speed AT some more. . .you might find your car is pulling the same revs in 5th as it would with the 4 speed auto,aftermarket ecu to run it? MIGHT be something out there
Not so interested in the revs in the last gears. More interested in the extra pull from the early gears.
I found the gear ratios in comparison to the 4 speed, once, a while ago. Cant find them again. But it was something like this:
1 - 3.857 - 2.785
2 - 2.140 - 1.545
3 - 1.384 - 1.000
4 - 1.000 - 0.694
5 - 0.694
  • 1 year later...
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
