Hi All,
After a recent exhaust upgrade on my 'line I have a Trust superdragger style stainless rear muffler for sale. All mounts etc are to suit a '95 R33 GtsT and connects to a std (2.5") exhaust system in front of the rear axle (need a flange break put in).
Don't know about exact gains but I had a completely stock exhaust system on mine and after fitting it, my 'line seemed to rev a lot better as well as sounding awesome!
I'm looking for about $200 for it but will take nearest offer, and would prefer melb buyer. If interested pls PM me.
-Anthony.
chopobo: yes it does have a 2.5" inlet (assuming the original stock system is 2.5"!)
muck: Not as loud as my current 3.5" system from the turbo back :-) but yes it does rumble.....not too bad inside the car as the stock cat etc etc help.
i'm wonder
the inlet of the muffler would be 3" with piping into a flange that is 2.5" right
so its pretty much a turbo muffler except with a 2.5" bolt on flange
so i can still put it on 3" piping
eriktufa: not sure.....has about 1m of piping before the actual muffler so it is possible. Download the pic and ask an exhaust shop!
chopobo: The inlet of the muffler looks like at least 3 -> 3.5" (I haven't measured it). However cut off the reducer (2.5" -> 3.5") and fit a 3" -> 3.5" reducer (or whatever reducer to suit) and it'll fit your 3" system quite nicely :-). Check the overall pic in my orig thread and you can see the reduction at the very end of the piping....
Fatgts-r: As far as I know Trust don't (or didn't) actually label their mufflers so it is an ORIGINAL trust muffler. All the muffler has as ID is the JASMA plate (jap compliance like ADR's over here).
Dave: I live near Caulfield and work in Moorabbin....so take your pick :-)
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
