Mmm, no pics on todays update as I can't be bothered getting my ipod cable.
Mounted the SW motorsports hydrolic handbrake today, sitting nice and upright next to the gear shifter. should be easy to use. cut the centre console trim and the dash trim to suit, fits in nicely and should look tidy enough.
Got rid of a bit more sound deadening, and then got over it and decided the rest can stay.
Also welded up the hole in my TRUST cooler, was a freebie courtesy of Paul at Option1Garage, GTR style trust cooler with a hole in the cold side end tank. All plated up now so should hold pressure fine and work well for what I plan on using it for! Thanks Paulie!
I also ordered my clutch today from NPC performance clutches, dougie's helpful as and bloody cheap! And ordered my injectors.
tailshaft next week, and then it's just wiring away from firing up. :D looking forward to hearing the idle...
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
