I have hooked up a new boost gauge (psi) but it stops at 5psi and slowly creeps to max 6psi, can anyone help me out with where i have gone wrong, ill post a pic with it.
There is a copper restricter or something in the t-piece that you can roughly see on top there, is it meant to be there?
btw i have a atomic mbc from gfb installed and running .75 on the standard gauge which is just under 11psi if my math is correct.
Edited by jamie curran
https://www.sau.com.au/forums/topic/366716-max-5psi-on-gauge/
Probably a pin hole in that plastic fish tank hose your using.
the hose is fine as i just put it on, i know its a common issue people have had, just need to know if ive hooked it up right
whats the common issue people have had?
not being able to install boost guages properly?
that hose is ordinary as dude
seriously go and buy some real hose from autobarn/repco/bursons
its probably flexing under pressure and then leaking
there is no "common issue" of aftermarket boost guages not working
wow, i am so glad i could get on here and get some useful support from people.
@paulr33 im really sorry the words "common issue" annoys u so much but the reason i said it was a common issue is because when u look it up u get around 100 results from all different cars and gauges.
whats the common issue people have had?not being able to install boost guages properly?
I am not saying i know how to install a boost gauge properly, this is the reason i am posting on here.
It may be crimping where it goes through the firewall, that hose isn't reinforced, and when it heats up it will just collapse like an old garden hose. Like the guys have said, you want some good reinforced rubber hose, or a solid nylon airline type hose.
Try another port?
can you explain that in dumb terms please :)
The brass restrictor is to help control boost pressure to the actuator.
so i should put the brass restrictor back on?
What brand of gauge? My first cheap one was reading 3psi low.
its a glowshift gauge, just a defi copy.
yes the restrictor is there to limit the volume of pressured air making it to the gauge. think of a straw with 5psi through it. now think of a 4 inch pipe with 5psi through it. both have 5psi of air. think about what psi is. pounds per square inch. so 5psi through a straw may do nothing more than blow bubbles in your milkshake. through a 4 inch hose 5psi might be enough force to push open a steel door. cheap gauges have cheap insides and having a big volume of compresed air in there is not good for them. it's there to protect the gauge. it also effectively shortens the intake tract as all those little hoses need to be filled with compressed air when your engine goes onto boost. not likely you'd notice 1 length of 4mm or 6mm hose but they can add up.
Is it possible you can borrow a gauge from a mate to test it?
The best place to tee that hose is from your fuel regulator. You either currently have it hooked up to the blow off or the vacuum canister's source...
Meaning either the blow off or the vac can could be bleeding some boost and making the guage read wrong.
As stated, the most fool proof place to tee it from is your fuel regulator. Tee it there and if you do not see accurate readings try another boost gauge.
GL
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
