Same idea as gas. For me the car is a daily and I did the experiment with my van ( 75/25 mix) and got morerange out if it.
Ok so the soft lines need to change?
I played around with non pump ethanol blends when I had the PFC in my 33 25T and while its interesting its a PITA after a while . I just stick to Eflex from the one servo nowdays and although Insight fitted and tuned my "V66" plug in I've been doing all the pre boost tuning . When you've had the alky a while you can't stand the smell of raw ULP or its exhaust fumes , using it pushes you to fiddle with the ecu settings trying to get the best drivability torque and consumption figures .
Something I reckon plays a big part in drivability and consumption is the injectors you use and most people use bigger ones obviously . I am keen to try some sort of current tech Bosch EV14 like IDs because I sometimes come up against minor drivability issues and I wonder how much of this is caused by using dated injector technology . Spray patterns and droflet size must become more critical the shorter the injector pulse width gets and thats were a lot of part throttle urban driving obviously is . The injector transients must be a fair bit faster with modern injectors and that would make tuning easier I suspect . I think the bottom line is if you want production car like drivability and a shot at good consumption you have to use good injectors from the outset . If perfect round town drivability and good consumption is not important then anything big enough that you can get to "idle" acceptably may be ok .
Production cars are pretty well behaved generally and they show up your ride if its a bit how ya goin' .
Having a wide band controller wired into your ECU is a great idea and I wouldn't be without the Tech Edge now .
Later I may play with flex fuel but ATM Eflex is good for me .
A .
My understanding of ECU tuning is limited. I can wire the thing up without issue.
Injector sizing again I am relying on other people for this. Was told GTR would be the right size and right impedance for what I have.
The Link unit seems to pop up in a lot of threads hence the reason I was looking at it.
What ever I buy is getting pulled apart and tossed into the stock ECU casing for ease of use and making the thing a lot harder to pick out if the car gets inspected.
Since I have time tomorrow I am going to talk to one of the people that sell link locally about the flex fuel option, time taken to set up and the data output idea I have.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
    • Shit. Starting to look like a car again.
    • its Masterton Motorplex just over the hill out of wellington.
