JonnoHR31 Posted June 5, 2011 Share Posted June 5, 2011 yer bigger pipe would flow more air at the same afm voltage Link to comment https://www.sau.com.au/forums/topic/366729-air-flow-meter-after-turbo-right-before-throttle/page/2/#findComment-5850936 Share on other sites More sharing options...
simons987 Posted June 5, 2011 Share Posted June 5, 2011 A suggestion if its for for a track car is to change ecu and get rid of the AFM and go MAP, I would personally stick with the AFM and keep it in stock position track car or street. Depending on the amount of power your making and CFM you require unless your car is making near 1000hp a setup like this will make 5% difference in your setup.. As Status mention he literally needs to cut and epoxy the afm on the cooler piping to avoid it popping off and for a track car you'd be putting so much more stress on your setup then. Link to comment https://www.sau.com.au/forums/topic/366729-air-flow-meter-after-turbo-right-before-throttle/page/2/#findComment-5851086 Share on other sites More sharing options...
STATUS Posted June 5, 2011 Share Posted June 5, 2011 A suggestion if its for for a track car is to change ecu and get rid of the AFM and go MAP, I would personally stick with the AFM and keep it in stock position track car or street. Depending on the amount of power your making and CFM you require unless your car is making near 1000hp a setup like this will make 5% difference in your setup.. As Status mention he literally needs to cut and epoxy the afm on the cooler piping to avoid it popping off and for a track car you'd be putting so much more stress on your setup then. as a note it is actually a trick i picked up from serious time attack cars in japan about 10-15 years back, so it does work fine in extreme cases too but i agree that it should only be done if there is no other option.... oil saturation of the afm element is possible if its not set up right or the engine /turbo is tired. Link to comment https://www.sau.com.au/forums/topic/366729-air-flow-meter-after-turbo-right-before-throttle/page/2/#findComment-5851305 Share on other sites More sharing options...
XRATED Posted June 6, 2011 Share Posted June 6, 2011 I was actually thinking of getting an alloy 'jiffy' box welded onto the cooler pipes to house the board.. But hey, if epoxy works- I'll give it a go. Cheers Justin Link to comment https://www.sau.com.au/forums/topic/366729-air-flow-meter-after-turbo-right-before-throttle/page/2/#findComment-5851459 Share on other sites More sharing options...
D_Stirls Posted June 6, 2011 Share Posted June 6, 2011 Has anyone looked at using one of the ford lightning AFM elements. you can just use the element itself or you can get them with an element and a housing. They are around $200 and they support 800hp in NA applications. Nistune has the VQ maps for them provided in the VQ table, so finding the VQ scales wouldn't be hard. Link to comment https://www.sau.com.au/forums/topic/366729-air-flow-meter-after-turbo-right-before-throttle/page/2/#findComment-5851622 Share on other sites More sharing options...
STATUS Posted June 6, 2011 Share Posted June 6, 2011 Has anyone looked at using one of the ford lightning AFM elements. you can just use the element itself or you can get them with an element and a housing. They are around $200 and they support 800hp in NA applications. Nistune has the VQ maps for them provided in the VQ table, so finding the VQ scales wouldn't be hard. ive used them with pfc, they work well. Link to comment https://www.sau.com.au/forums/topic/366729-air-flow-meter-after-turbo-right-before-throttle/page/2/#findComment-5851676 Share on other sites More sharing options...
rb20love Posted July 6, 2011 Share Posted July 6, 2011 hey thort id get in on this seeming as im coming up to doing my cooler piping with a inline afm can anyone post picks up of there afm running inline???. im a bit confused as to how this would go seemin as the afm has a flange on one end... heres my setup Link to comment https://www.sau.com.au/forums/topic/366729-air-flow-meter-after-turbo-right-before-throttle/page/2/#findComment-5901072 Share on other sites More sharing options...
BlueRB240 Posted July 6, 2011 Share Posted July 6, 2011 90mm Ford Lightning maf in a 2.75" pipe. too small needs to be at least 3" or 3.25". Link to comment https://www.sau.com.au/forums/topic/366729-air-flow-meter-after-turbo-right-before-throttle/page/2/#findComment-5901103 Share on other sites More sharing options...
