Entry
https://secure1.ilis...ntroduction.php
Sub Regs
https://secure1.ilis...t_Supp_Regs.pdf
Requirements
CAMS L2S
CAMS club membership with current date (SAU VIC Membership)
Fire Extinguisher
Two bonnet latching mechs (the standard double latch is ok, but for older cars with the single latch no good you need a second with a tie down strap)
Blue battery triangle 150mm x 150mm x 150mm (get yourself some blue contact from the news agency and cut one up!)
See you there.
2011 SAU VIC Motorsport Championship proudly sponsored by:
  • Replies 163
Posted Images
PIARC Saturday are not timed, but racechrono works fine. The Saturday PIARC are also grouped as follows:
- race cars
- experience drivers (fast)
- newer drivers (slow)
- open wheel
- karts
I would defiantly be doing PI in place of Sandown for EC practice Russ. Also Alfa are at PI on the 2nd of July.
- race cars
- open wheel
- karts
Thanks for the info. Yeah PI is the go I think... We'll see how tuning goes before I commit to anything anyway.
Fixing up my paperwork but came accross this:
:O
f) Noise emission level is limited to 75dB(A) at 30 metres. Competitors who fail the drive-by 75dB
reading will get 1 (one) chance to rectify the problem and will be excluded if the car fails on a second
reading there will be no exceptions.
If you have ex gate, you will not pass. Straight through exhaust will be pushing it, side exit exhaust will fail.
Normal cat'les exhaust with a cannon will pass easy.
Roy got done at the last sandown, as did a tier 3 V8 Supercar.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
