  • Replies 163
Posted Images
Wheels...what wheels.
All the arms are back on the car and it drove ok. Just needs a wheel alignment now. I'm guessing the front LHS hub and mounting points for the tie rod and the lower arm may have moved a little.
But time will tell.
Lol did anyone actually read the new supp regs in regard to the fire ext. mounting? Not sure if this has come directly from CAMS (wouldn't surprise me!) but the supp regs read:
b) Must be fitted with a fire extinguisher securely mounted on a metal bracket with metal straps within the cabin and readily accessible to the driver whilst still in the seat belt or harness and which complies with AS 1841 (save that extinguishers which meet AS 1841.2 are not permitted), and be of at least 900gms capacity. Halon/BCF extinguishers are not permitted. The extinguisher and the bracket must be a compatible set, (i.e. as supplied by the manufacture of the extinguisher.) The extinguisher should be retained within the bracket by at least one (1) metal strap. The bracket should be secured using a minimum of 2, Grade 6 or greater bolts, of a minimum 6mm diameter, and self - locking nuts. A suitably sized body washer may be required to provide extra support for the bracket. The securing system must be able to withstand a 25g deceleration.
The part in question is the bit in bold regarding Grade 6 bolts. There is probably no way that the scrutineers on the day are going to check the markings on the heads of the bolts 8), but the problem is that grade 6 bolts are no longer made and herein lies the problem....The supp regs say grade 6 or greater, but the next grade of bolt is the grade 8. Sure this is a 'harder' bolt but is prone to breaking due to the brittle-ness from the treatment ie under load it is more likely to shear the head off. The lower grade 5 is the bolt used in automotive apps as it is still 'hard' but due to the lower level of heat treatment is more likely to stretch under load rather than shear.
So bottom line, I'm going to use grade 5 or 8.8 bolts....
lol @ self tapper.
Have a read of the entire reg though Ant, its all pointless anyway/not ever followed.
There is no chance in the world, strapped into a harness, that you'll be able to reach the extinguisher unless its bolted to the roof above your head!
Given the purpose of a harness is to stop one from moving!
Yeah I know....but I'd be kicking myself if I turned up, paid the money and they knocked me back because of something so small :(
Hy Ant, what's your previous best at Sandown?
Sandown makes me scared so prev setup only yielded a flat 1:23. While I will be aiming for teens, I will be held back by the fact my balls are smaller than usual at Sandown :yes:
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
