  • Replies 163
Posted Images
Ha a bit damp at Sandown, maybe I should have booked that tray tow as well
I have put someone in a Nissan and from SAU in the Driver Training assessment group 6.
As its a new license and no experience listed on form.
I am putting this group out first so that they can be helped.
If they are all safe and been introduced to the track , I can them move them into group 5.
So we then only have the 5 groups I planned and everyone gets maximum track time.
I would greatly appreciate one of you taking them under your wing by signing on as a Driver Trainer and giving them the benefit of your experience.
(like dont try to brake from 200kph in the wet going into turn one at the 50meter mark)
Totally worth it to see Jack and Ant sliding onto the main straight.
Icy and cold in the morning....I was shivering inside the car.
Car drove home, win win.
Looks like I'll be back their again next weekend, if not wet!
http://www.nissancarclub.org.au/Events/?e=224
Popped in quickly, last turn def looked like a bit of fun.
Will do the same - also only if weather is looking good!
Yeah too bad about the shitty weather, I was taking it easy the first couple of sessions then it started raining. The Z06 corvette coming on full noise down the straight sounded so good :worship: The M3 CSL was nice too. Was awesome seeing Luke and Anthony's long power slides coming on to the straight :D
John you're a nut behind the wheel!!! Nice times :thumbsup:
Twas a good day today, good job to the boys in the skylines! First time going to an event like that for me, makes me keen to get off my Ps and get mine set up for a punt on the track, looked hella fun, especially that last corner, the few WRXs went off, cringed. Any way i can grab pics from today that are on FB and post them here? or is it easier to just re upload them to photobucket?
Damn the weather gods! Was looking forward to Sandown for two reasons, one I have a lot of unfinished business there and secondly I was looking forward to sampling my new setup at the track. Well after the day, I still have unfinished business there but I did enjoy sampling the new setup even if unleashing the new ponies in the wet wasn't what I had in mind :)
Well done to all SAU peeps for keeping it off of the walls in some challenging conditions. Getting used to a new setup can take some time but after the first two sessions when I felt confident the rain hit...basically the only session that was dry was the practice with only light misty rain falling, 1st timed session got heavier and after that just got worse. Whilst lap times were out of the window, I did enjoy sliding the car through the last turn and turn 1 and I had a ball! That being said, feeling the car twitch under full noise in 4th and 5th gear in the two straights when hitting standing water was....errrr...interesting :blink:
Also met a fair few SAU members in the pits, so was good to meet you all.
Bring on the next round with will hopefully be dry!
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
