If you have ex gate, you will not pass. Straight through exhaust will be pushing it, side exit exhaust will fail.
Normal cat'les exhaust with a cannon will pass easy.
Roy got done at the last sandown, as did a tier 3 V8 Supercar.
Are you 100% sure external gate wont pass? :( doesn't brisby have ext gate?
Ahh so Troy did get in trouble at the Sandown day. Hmmm... I think plumb back is the safest option
  • Replies 163
Posted Images
Should I be bringing some new front pads for this? havn't changed them since I got the car lol.. Dont want to go into a wall at 250k's
Sorry Leigh. Not trying to be a dick but you need to do some reading in the motorsport section and other parts of SAU and also the net about racing.
You have a boat of a car (all GTR's are) and your brakes have to be in good condition. Get some good pads and fluid as a minimum and I suggest having spares of both. I used to have spare rotors with me too!!!
I'd hate to see you smash an expensive car.
There is a lot to learn so get some research into ya!!! :)
Just a sticker on your car showing where the battery is. For WRX sprints it's only required if your battery is NOT in the front under the bonnet.
That rule is only for the default car of the club running the day...ie a WRX. All other cars require a battery tri-angle.
Blue piece of contact from the news agent, cut up is easy enough. Stick it on the body pointing to the battery.
Do you know what pads are in there? How much meat is left on em? While what Russ says is true. Youre just starting out and wont be piling the speed and deceleration on as much as we do. So you may not go through the set, but OEM like pads don't cut it at Sandown. I scared myself shizles the first time I went there on lucas pads. Those kind of pad go from, sponge to nothing. So you get sponge coming onto the main straight, then nothing into turn one...
I can help you on Saturday swap the pads and bleed RBF600 into the lines if you like. The alternative is to do two laps with the current setup, cool down for two then go for another one then come in.
A1RM's as a minimum with Motul / Martini Racing RBF600 fluid.
I was going through 2/3rd of a set of an A1RM at each Sandown Track Day when I got confident.
No, it applies to all cars entered on the day, not only WRXes. I will have one anyway because the Alfa club supp regs require it.
lol fair enough... my comments are simply based on my experience, and what the supp regs say. If it's not on the scrut sheet they wont check it. I will have one for this round regardless because it's in the supp regs for the alfa club event this weeekend. :thumbsup:
That triangle thing has changed. It used to be if it's non-WRX or anywhere non standard on WRX's needed triangle.
Also...
c) All vehicles must use two separate fasteners on any front opening panel
Everytime I've been to WRX days they say that standard isn't enough. They say it needs to be 2 'separate systems'.
Not sure if you have the cable trick John or if you just have standard 2 motion latch?
I've seen standard latche fail on a 33. I recommend the extra cable or pins.
I have an extra cable with a climbing shackle.
But you can also still read that either way. The standard unit has two separate fasteners, they are not 'mounted' separately. But they are different devices.
I keep an extra bonnet strap in my bag just in case. It's still not clear to me if it's required based on sup regs (whether or not secondary factory latch qualifies as 2 bonnet restraint systems), but definitely a good idea to have if you don't have bonnet pins fitted. You don't want your bonnet flying up at 200+ km/h!
When are you back in action Ant?
Ant can't be far offfrom what i saw last week.
Looking good
...and there I was creating some 'mystique' around when the cars ready ;) jk....
Realistically with a bit of time to take the car through the twisties to start getting used to how its driving I'm still aiming for this day as its first outing.
Guest
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
