Hey guys first post here woooo. So sorry if this is in the wrong place, admins please feel free to move it if it is.
Anyway I just got my P license a couple of weeks ago and was looking to buy a car. Ive been extremely keen on buying either a Nissan 200SX or 300ZX as i love the general shape and look of these cars, and ive also heard great things about Nissans in general. Now i dont know much about cars, and so i need some help from you guys.
The Queensland Laws in regards to high powered cars are as follows:
High powered vehicle restrictionsA high powered vehicle restriction means that you are not allowed to drive what the law calls a “high powered vehicle” on a road.
If you are:
  • under 25 and on your P1 or P2 licence
  • any age but on your P1 licence after being disqualified for an offence which happened when you were under 25
then it is against the law for you to drive a high powered vehicle on a road.
The law says that a high powered vehicle includes:
  • an engine that has a power output of more that 200 kW
  • an engine with eight or more cylinders
  • a turbo charged or supercharged engine (but not diesel powered engines).
So ive mostly been looking through the news paper and on www.carsales.com.au for a car, and am getting confused about what I am allowed to drive and what Im not allowed to drive.
Take this 300ZX for example, it specifically says non-turbo, but is its engine output under 200kW? (And yes i know its kms are quite high but im still looking and just posting it up for examples sake)
The same with this one, it also says non-turbo. (This one is 4 seater which i like more because i have friends i like to drive around). What does the cc value of an engine mean? Because i think these are both 2960cc engines.
Thanks a lot for any help,
Isaac
https://www.sau.com.au/forums/topic/366738-queensland-p-plater-laws/
Welcome!
If you're ever unsure about a car's power output, try wikipedia or redbook. They'll generally have what you need to know.
http://en.wikipedia....G_engine#VG30DE - The VG30DE engine the the 300ZX makes 166kw at the flywheel and is legal for Queensland provisional license holders.
The cc of an engine signifiies the displacement. In the case of the 300ZX and the 2960cc, it's a 3 Litres engine. 1000cc is the equivilent to one litre.
Edited by Truffles
Isaac
hey bro.
Just to help you out Both the 300zx and 200sx have power outputs below 200KW
like the guy above said look through wiki:
300ZX - Nissan 300ZX
200SX - Nissan Silvia
By the way im not sure there are many Non turbo/Super charged 6 Cylinder or less cars above 200KW anyway.
hey bro.
unfortunately, the S14 200SX was Australian delivered and they were all turbo. Therefore, you won't get a N/A S14 200sx that's legal for a QLD [P] plater.
And you're generally correct. Apart from the SIDI commodore and the V35/350Z, I can't think of many N/A 6 cylinders that make 200kw that aren't highend. Like an BMW E36 M3. Correct me if I'm wrong.
The main point is that the 300ZX is completely fine.
Edit: Toyota Aurion makes 200kw on the nose, but no one wants FWD.
Edited by Truffles
Ok thank you so much for the help guys, you just made me very happy haha.
One more question, do any of you guys know how good/bad the 300zx is on fuel consumption/cost?
Thanks again
Edited by biggest_kid
a 300zx will have ordinary fuel economy, since they are a v6 and a bit on the heavy side. the economy would be similar to that of a commodore or falcon. somewhere in the range of 10 to 16L/100kms, depending on driving. highway will be down around 10L/100kms (or even a touch less), but heavy traffic and giving it the beans on a regular basis will see it up around 16L/100kms.
ok thanks for that piece of info, that explains why it was very very rare to find a non turbo s14 in AUS (ive only seen 1 or 2 for sale)
Thanks again
mad082 basically sumed it up......3.0L V6 and at roughly 1500KG it will tend to use a fair amount of fuel.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
    • Try using Penrite 80W140, has Limslip predosed into it
