Import Monster Sau-Vic Deca - Round 2 2011 Wrap Up Thread
  • Replies 150
Posted Images
OK so my videos from the skid pan are finally up
There are 2 different versions however both are the same videos
the standard def version is here:
http://sau.loudsx.com/decajune11/lowres/'>http://sau.loudsx.com/decajune11/lowres/
these are 7-10 mg each and will play on most anything.
the high def ones are here:
these are in MTS format and are the full HD and are 50-100mg each.
if you don't know how to play mts files.....stick to the SD ones.
if you want to reuse that's fine, just credit myself and SAU where you use them.
Alternatively i will have them all at the June meeting if u want to bring a usb thumb stick to get them.
enjoy!
Great job mate, looks great!
Tim: You're shit.
I love you too Kieran :blush:
Thank you all for the abusive messages on Saturday night, i don't know what i'd do without you all, i felt so loved/unloved.
Things iv'e learnt being Tim Bryan:
1: Never not drink at a DECA
2: Never not go to a DECA
So i guess I'll see you all in November yeah??
ok so re the videos...
what are ppls thoughts going forward?
I saw from the hits that the low res was much much more popular that the HD videos.
So are people wanting the HD ones going forward or just stick to the Lower res ones?
or continue with both?
Oh and a little reminder...don;t reference where the vid came from when u repost...no videos next time....
cheers
M
cheers
M
You don't want credit for your work???...
Downloading video files is a bit '90's isn't it? There is this new thing....forgot what its called. Ah that is right...youtube
yeah but quality on youtube is a bit crappy, plus if you want to play with the files make a compilation etc then you need originals.
plus lots want to upload the video of them to their own channel. so this way they can.
happy to just upload the lot to youtube, but think there will be a lot less happy ppl!
+1 to all you said Martin.
Uploading and then letting people do the editing/work themselves is much easier from your point of view :)
I'll end up putting it on youtube or something, of course crediting the work ;)
cheers
M
I was at work... so i just downloaded the low res first...
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
