hey guys
recently ordered some BC br series coilovers. however have decided to use a different brand coilover now as i want a true coilover rear setup, not oem seperate coil/strut.
So the BC's are not needed. i bought these for $1200 delivered, received on thurs last week, havnt even removed from box. all paperwork, stickers and spanners included of course!
im looking for $950... thats a cheap price for brand new coilovers!
located bris/goldcoast...
best to msg on 0416702037
thanks alex
PS,
im hoping i dont need to put pictures up.. they are all wrapped up and dont really wanna cut them open for a few pics
I would personally reconsider going true coilover on the rear. I know it's been done, but that doesn't make it a good idea!!!
The rear mounting points are not designed to take the weight of the car unless you plan to reinforce the area.
If you are trying to save weight have a look at what's available
http://splparts.com/store/product-list.php?pg1-cid16.html
May I ask why? Converting the rear to a coilover arrangement takes a lot of work. I'm wondering what gains you hope to realise from doing so.
with converting it he can buy a 'standard size' spring for that coilover and pretty much any spring rate he wants. the BCs arent straight springs on the rear like they are on the front
Wouldn't it be cheaper to just get a custom spring made up at the desired rate / height, rather than converting to a coilover and having to reinforce the mounting points (or getting custom arms) since the load is now concentrated on one point rather than being spread out over 2?
I've seen a pic of some people who've done it on off-street cars on a 350Z forum a few years ago, but searching Google comes up with no matches for information on how to do it. Having to figure it out for yourself seems like a pretty expensive job, for little appreciable gain. I'm pretty sure the companies that did it had to reinforce the damper mounting points to handle the extra pressure they'd be put under, and weren't designed for.
sorry i was just saying thats the only reason why i would want to change to a 'proper' coilover setup.
my BCs are fine! i dont mind that they are seperate.
and i agree about the mount point. its fairly weak for the contant barrage of australian roads pounding that spot on the rail. it will crack and break in no time.
"Stance" and "k-sport" make a drop in rear coilover for the v35/350z.. no mod work required.
Im not worried abour the strength factor of the rear mounts, i can simply get the boys in the chassis shop at 888 or PMM to beef them up for me. and yes there is a much wider range of spring options in a conventional style coilover rear.
Thanks for the helpful feedback tho guys, i am going to use the BC's now while my new setup is on order.
thanks again
ive wound mine tight as im not a pussy :P
anyway the softer damper settings are very good, and wife/gf/fcuk buddy friendly. harden them up and they only get better. just dont go too firm as its not really suitable for the street and street tyres.
full height adjustment and spring pre-load is good to have also! front and rear too
ohh AFAIK justjap sell an $1100 set and $1300. i believe its the damper cartridge that is different........
I rate and rock BC BR Series on my V35. One the hardest setting is it still comfortable for daily drive, I reckon it is still too soft compared to my Silk roads on the R32. I'm on stanced/flush/offset, hardest setting and tires still srubs front fender on hard cornering.
Rear shocks and springs are separated just like oem setup. Took 3 hours to install myself on dark and tight working area including height adjustment.
My sisters V35 is rocking with BC BRs rear and front fantastic coilovers plenty of haters because not JDM enough lol
just make sure to adjest hieght and dampers to your liking.
I am also repping BC for my Euro and Stag
Not to hi-jack the thread but whats a "True rear coil over set up" ?
After I get my tax return, I plan to get HSD HR coilovers with spring rates of 10kg front and 12kg rear and you guys got me worried talking about what Mosoto said:
"The rear mounting points are not designed to take the weight of the car unless you plan to reinforce the area."
I got a set of sway bars for my birthday and plan to put them on with the coilovers. Will this help or worsen the situation? Sorry if that sounds dumb.
Sorry,
I have a question aswell. Initially i was wanting to go with a true coilover setup (Stance GR+ Coilovers), i wanted these because i liked the fact that the spring was mounted onto the strut.
But after reading your recommendations on the BC Racing coils, i've decided to go with the BCs.
My question is, regarding Toe. Will lowering the car require Toe to be adjusted? i read on some forums that this needs to be done.
Which is why i originally opted for a true coilover setup, because you can just buy adjustable toe arms to replace the spring mounts.
Going with a OEM coil setup, i belive Toe bolts are required which needs drilling (i would like to avoid any sort of drilling or modification).
Is Toe something that needs to be considered? i know rear camber is a must, and front camber is optional. I plan on lowering just to reduce wheel gap, nothing drastic.
The rear weight of the V35 is taken up by the springs/Mid link setup. The shock mounting point does not take the weight of the vehicle, only the resistance from the shock with the travel of the suspension. When you combine the shock & spring in a coilover the midlink is removed and replaced with the Toe link (see SPL link in my 1st post). By doing this you are transfering all the rear vehicle weight to the shock mounts, this of course is increased exponentially by body roll & acceleration (rear squat). In racing circles the shock mounts at the body will be reinforced & braced to accomodate, so unless you plan to strip the car and go racing there is absolutely no gain to be had by going true coilover on the rear.
I have Ohlins coilovers on mine with the standard rear setup and can get just as much adjustment that any true rear coilover setup can provide for the street. In fact I have plenty of ride adjustment for the track too.
OK I kind of get you... so how do I get hold of re-inforcement for the shock mounts like you mentioned? Is it a simple kit or add on that you screw on or would it have to be welded on? I do plan to take the back seat and strip the back as I am slowly making this car my project track car so what ever option you can recommend I'll consider.
OR basically you recommend that I dont put coilovers (the HSD im getting) at the rear? What about new springs with higher spring rates?
Edited by Bourbon Boy
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
