Well there is a chance that they will make 10%.
So vote Liberals at the next election.
And if any1 have a chance to speak to Libs leader (before elections)
maybe he could ask a question regarding the buffer on speed cameras.
I would love to hear the answer (may be a lie anyway)
And if you be so lucky to shake his hand dont forget to count your fingers (you never know)
Yeah, I remember rthe Liberals saying they were going to put it back to 10%...
What I don't understand with the current system, is that someone once mentioned that the ADRs state that a vehicle's speedo must be accurate to +/-5%. Now if that's what Federal law states (and if I'm wrong, someone please correct me cos' I'd love to know!) how the hell can State government come up with a law stating we will only allow 3%?
If it's true we could all get proof that our speedos are 5km under (putting larger tires on if we must! :D) taking that to court, and getting these stupid 3km/h over fines thrown out!!!
  • 1 month later...
agreed
This probably sounds geeky but anyway in scientific measurement (which is measurements off any scale) the number is always accurate to half the increment... so in my car there is increments of 10km/hr so if i'm going 94 (accordingf to the speedo) it could be that i'm actually going 90. but equally so if i'm going 95 it could be that i'm going 100...
(scientific error - if anyone knows what i'm talking about)
Kor
agreed
Kor
geeky but true davor... :)
nothing is accurate without an error margin specified.
and as for the liberals bringing back the +/- 10% system: i believe this is not only a fair option and a potentially elecion-winning proposition, but a feasable one as this party will actually be able to keep victoria out of debt without having to rape the wallets of every victorian to do so.
moral of story = bring back jeff...
If it's true we could all get proof that our speedos are 5km under (putting larger tires on if we must! :() taking that to court, and getting these stupid 3km/h over fines thrown out!!!
63 in a 60 zone is 5% over. So technically they are ok with that one.
LOL @ Chef_32
this shits me i mean yes i should have had my p's but i dont thinhk its worth 3 points
Not anywhere near as bad as 3 demerit points for dodgy number plates! I was fuming when that law got introduced. It is the icing on the revenue cake.
The other option you have as this is your first offence is to write to the transport authority and ask them to let you off.  If it is your first offence they most likely will.
This is a proven fact that has been covered in the media lately
This is true. I have seen it done. Write a letter stating how sorry and stupid you are bla blah and you should get off... It MUST be your first EVER offence.
Guest INASNT
im in cout atm for not having a front number plate copz it was stolen!!! but because it was my bday and i cbf reporting it, i get 3 pts and criminal record for protesting it to court....
just because u protest it doesent mean u will get any record
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
