Hi all,
I'm clearing out the shed of some un-wanted gear off my car that has either been changed, upgraded etc. Please note this is my first attempt at selling stuff on SAU, and I work alot, I shall do my best to reply to PM's, texts etc. and arrange freight/pick-up etc as quick as possible, but do be patient.
Best bet/preferred for contact is to PM me on here or text as I can't answer my phone at work.
Contact No: Josh 04 3774 5147
Can freight all items at buyers expense, pick-up is preferred from country south-west vic, exact location will be gladly given to interested buyers but would prefer not to list for security and privacy.
Also happy to deliver items/meet buyer half-way at buyers expense (fuel costs) if distance is reasonable.
Standard parts are off a R33 Series 1 GTS coupe' RB25DE
Fusion EN-AM300200 amplifier, 2 channel, runs 70w rms per channel, suitable for running a pair of 6X9's, is a flow through/daisy chain style amp so another amp can be connected to the same pair RCA leads, bridgeable to run 180w rms, good working order, removed as I went to a bigger system requiring a 4 channel amp. More details here. $30
Sub box built specifically for boot of R33 2 door, sits above the fuel pump area with the battery/fuses re-located, and HICAS ECU mounted to the drivers side, very snug fit. Made from 3/4 MDF with loads of liquid nails and screws, extremely solid, 2 separate compartments, "face-plate" made from 12mm MDF. Average condition, needs the "face plate" re-done/re-trimmed. Had 2 10" subs inverted mount running in it, again has been changed for bigger build, has filler to make the boxes ~14L each, could be removed to go as big as ~25L each. Could be cut out to fit 10" subs normal mount with spacers, too small for 12"s. $30 to good home
post-74990-0-62387700-1307252975_thumb.jpg post-74990-0-85462900-1307253080_thumb.jpg
Stock JECS fuel pump, upgraded, was in running car on removal, but slightly noisy (can be heard on priming and outside the car when running) $15
Two 205/55/R16 91W BCT S600 tyres, changed due to flats pots and worn shoulders, tread varies from %15-%60, suit drifting or burnouts. Not road usable! $50 pair
One Mazda RX8 space-saver spare wheel, 5 stud, off my old car, never used. $50
Standard sway-bars, no links, "D" bushes included $30 pair
Standard springs and shocks, no visible leaks, surface rust, typical condition for age $50 the lot
Genuine Mazda 5w-30 rotary mineral oil, un-opened, paid ~$70 for it yet never got used. $50
Speco-meter 2.5" (I think) electronic oil pressure gauge and sender, good working order, needs wires extended, lights up yellowish standard globe color $20
Random "Nakamichi" CD head unit, has AUX in, came with car, suit daily driver $10
2nd hand oxygen sensor, unknown age, only noticed .5L/100km improvement when changed, suit if you have an absolutely dead one or for testing etc. $20
6 standard coil-packs, acted up on stone cold nights at full load over 4500rpm when car was N/A, taping/greasing may help, suitable for diagnosis or temp-replacement $40
Have a few more small items for sale, but it's raining hard so can't get photos, will update later on.
Cheers, Josh
hey mate do you have a drivers side electric window switch, series 1 ?
Nah mate I don't. Not a full part-out, just some random bits i've changed. smile.gif
Also for sale:
Permatex Ultra-Black sealant, un-opened, un-used. Had my sump off on the weekend, got 2 tubes to be safe, didn't use this one, $15
Another couple items:
Standard R33 GTST intake pipe, no visible damage/splits: $30
Assorted Permaseal gaskets, got the kit for my conversion, only needed the T3 and dump pipe flange ones: $10
  • 1 month later...
  • 3 weeks later...
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
