time has come to overclock the PC i have now to squeeze more out of it before in about a years time going to an i7 chip, board and ddr3
Currently 8gb kingston value ram
2X 5870 Ati cards in crossfire
win 7 64bit
e8400 intel dual core @3.00ghz
as the KV ram @ 800mhz i have at the moment is a bit unreliable once the overclocking begins i'm looking into going some decent gamin ram like dominator etc
i'm unsure if my gigabyte ga-ep45-ds3p card can handle 1066 ram and if it doesn't will it work and be of any benifet
i'm lookin for about 3.5ghz to allow for detailed clouds whilst running fsx with a frame rate >25 with nearly full graphics
thanks
https://www.sau.com.au/forums/topic/366782-ram/
You can just buy some PC2-8500 sticks (1066) for $100
I CBF checking all my settings, but depending on the clock rate etc you might have to lower the ram timing anyway.
You could probably get away with the sticks you have now, if you go back to 4gb of ram.
My 1066 sticks are @ 450, 1:1 with 2T.
Thats for 4.1ghz with the mutli on 9x
My CPU has run this basically 24x7 for the last 3-4 years so if you have good cooling you should aim a bit higher than 3.5 IMO. You'll hit 4 easily.
4 sticks wont help your over clocking, should stick to 2.
https://www.sau.com.au/forums/topic/366782-ram/#findComment-5850959
apparently this mobo can use up to 1333 ram but i cant find any anywhere, its all ddr3 now :(
have 4 sticks of 2gb ram and the overclocking has not begun, doing more research before i begin.
the KVR are woeful at overclocking and i would rather just get better ram than spending ages messing with average hardware.
https://www.sau.com.au/forums/topic/366782-ram/#findComment-5854723
