I so should have got mine done.. but i full dont understand what im doing wiht my break system..
I have to get new breaks.
Possibly New rotors
Get them painted
But i dont know which order to do it and all that.
I mean you wouldnt wnana get paint on new rotors right?
and when changing breaks i have to take the calipers off to do that?
so then i should paint it?
but i wouldnt want to paint it before the new rotors because i could scratch the paint and stuff when trying to put the new rotors in?
im conffused :rofl:
  • Replies 53
lol. just pick up the car for gav's this arvo !! finially got 1.5bar from the turbos and 1st gear turns into loss of traction at all 4 till u snap 2nd and throws you to 100kms+ :>
really want to paint the brakes i did it on my old cars but they never turned out like the ones in the pics you guys posted
