Hey guys,
Just wanting to know if the r34gtr front pipe will fit a r33gtr?
And is it a upgrade on the standard r33gtr front pipe (inlet and outlet sizes)
I have picked one up very cheap and seeing if its worth the effort to change over when i replace the cat.
Thanks in advance.
https://www.sau.com.au/forums/topic/366828-r34-gtr-frontpipe-on-r33-gtr/
34 dumps are better than 33 dumps, but I'm not so sure about the front pipes. they are easy enough to remove/replace at home so by all means pull yours off and compare them to the 34 ones. might need to swap over some brackets etc from your 33 pipes to the 34 pipes. make sure you refit the gearbox bracket as it supports the weight of the front pipes otherwise they are hanging off the turbos... not good.
ok, so im just waiting on a cat then will do it, will take some measurements to see what the difference is.
The car is a daily so not after big power. Looking at around 350-400 rwhp when finished so i think these will get me there fine.
thanks for the input guys
