Hi guys,
Couple of interesting alternatives are available atm to the usual Walbro GSS-341/Bosch 040 options:
AEROMOTIVE 340LPH 340 LPH 90PSI HIGH FLOW FUEL PUMP
These are pretty new I think, looks physically almost identical to the Walbro, claimed 340LPH flow, available on (ebay) here:
http://cgi.ebay.com/...n#ht_4609wt_933
some Supra-related info:
http://www.supraforu...w-charts-review
...and...
Deatschwerks DW300+
These look promising and cheap at $169 US thereabouts (considering the exchange rate)... claimed 300+ LPH.
http://www.deatschwe...-tank-fuel-pump
Look like the Walbro pump again, no Skyline-specific model fitments listed but here are the physical dimensions:
http://www.deatschwe...fuel-pump-tech/
Anyone used either of these? Anybody have any recommendations? I don't know where fuel pumps are really at these days... everybody still use the Walbros, or...?
cheers
DaveB
Edited by DaveB
https://www.sau.com.au/forums/topic/366829-aeromotive-fuel-pump/
the 040 is too big for the stock setup
get the walbro, a guy down here in tas just bought a genuine one off ebay brand new for $140
same size as stock, easy to install, proven and cheap
One thing about both of these models is that they claim significantly higher flow rates than the walbro (300-340 as to 255) which I believe has poorer flow rate performance unless it's hard-wired anyway (though to be fair probably all pumps do?). Just something to consider...
the main thing to remember is that the c34's don't have a cradle like the skylines but instead have a box that clips to the bottom of the fuel tank
so going any bigger than stock will be a big pain to fit nicely without hacking up the box
I was looking to run one of these but they were twice the price and they also draw twice the current. I came to the conclusion they are great if you cant fit twin Walbro's in, as the twins will flow more at a similar current. Of course not too many people will need a 1000hp ethanol system anyway.
Tom, that plastic box looks very similar to what the m35 has. It may not allow enough fuel to enter the container if you run the larger aeromotive pump as I have found with the twins. Its only a problem at under 1/4 tank.
1000hp or 1000cc's??? farrrrrrrk
:woot:
So lets throw an ace in the pack hear
2x walbros = what..? 510lph?
To burn even 1 full capacity of a walbro you wd need serioisly big inj, running huge duty cycles.... With a tune and car to suit....
Why in gods cock would u need anything more than the quiet, easy to install, cheap, more than enough flowing walbro...:)
because they only flow 255lph at some shitty low fuel pressure
ah just found the chart, they also only flow 255lph with no fuel lines attached, Ill assume the Stag lines are 5/16" same as the Skylines...so try and blow 255lph through a long maccas straw.
please show me how it would be benefitial to have 2x walbros...
stock 25 inj run at 370cc... so all 6 at 100% duty (never come close to that safe) is 2220cc/per min...
1x walbro flows with no lines at 4250cc per min...
even half the flow rate for lines witch would never ever happen... and you could still run your injectors at ~99.6% duty... if someone was stupid enough to run this higher %. they deserve to be kicked in the head lol....
scott upgraded the fuel lines to braided SS , pressure reg, and 1000cc injectors.
hence: beneficial to have teo walbro pumps.. the way its set up is, one pump runs one fuel rail(theres two as v6) so makes if efficient!
1000cc is just the spec of inj....
what sort of duty is he running... all these mods mean nothing more than the amount of fuel the car ACTUALY chews per min...
im not saying what hes done is wrong or right... just wondering why he has done what he has more than anything.
and wouldnt the braided lines flow much better than stock...?
having 6000cc worth of inj
and 8500 worth of fuel suply,
at 100% duty. he has 30% or so too much fuel b4 the lines... leaving him well ahead.
what sort of % would he run?
Edited by chef_stagea
he maxed out the fuel lines on the last run. with the gtx going in he wanted to be safe so he knows that atleast his fuel system will be able to cope.
i think i recall him saying that he had already made the twin pump setup before he found the problem to be the lines, so he used i9n anyway.
but can definitely see your point.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
