Only selling as my wife is pregnant and we have just purchased a new family suv so pretty soon this will be impractical,better than let it sit in the garage and never get driven it would be better off going to another skyline enthusiest.
Will get newer better quality pics uploaded when I can figure out how to resise them
97 R33 SKYLINE SERIES 2 - 40TH ANNIVERSARY EDITION
98000KLMS
RB25DET MANUAL
ARCTIC WHITE
15% DARK TINT
FACTORY SERIES 2 FRONT BAR
URAS TYPE 2 SIDESKIRTS
GTR REAR APRONS
NISMO CLEAR SIDE INDICATORS
DAMPER ADJUSTABLE KYB COILOVERS
SLOTTED REAR BRAKE ROTORS
18INCH STARCORPS, 8.5 INCH FRONT, 9.5 INCH REAR
BRAND NEW STRETCHED 225s FRONT,NEW STRETCHED 235s REAR
30MM SPACERS FRONT,AND 10MM SPACERS REAR
ROLLED FRONT GAURDS
FRONT MOUNT INTERCOOLER
R34 TURBO (OP6 BIGGER REAR HOUSING)
TURBOTECH BOOST CONTROLLER(98% NO SPIKE/BOOST CREEP DESIGN,HOLDS BOOST STEADY)
DRIFT BOV
POD FILTER
JUN STRUT BRACE
D1 SPEC OIL CATCH CAN
FULL XFORCE 3.5INCH TURBO BACK,XFORCE CANNON MUFFLER
BOSCH 040 FUEL PUMP
ADJUSTABLE MALPASSI FUEL PRESSURE REG
EXCEEDY HEAVY DUTY CLUTCH
HICAS LOCK BAR
TOMEI 2 WAY LSD
REMAPPED ECU BY EASTCOASTCUSTOMS
NISMO SHORT SHIFTER
FACTORY S2 LUMBAR ADJUSTABLE BUCKET STYLE SEATS,40TH ANNIVERSARY EMBLEMS
REAR AND SIDE 40TH ANN BADGES HAS BEEN SHAVED
PIONEER HEADUNIT
KENWOOD 300W SPLITS FRONT
PIONEER 220W 6.5INCH REAR QUARTER TRIM MOUNTED
BLUE LED SPECO BOOST GAUGE
GREDDY TURBO TIMER
BLUE LED DASH
BLUE LED CLIMATE SCREEN
BLUE LED CLOCK
BLUE LED KEY RING LIGHT
BLUE LED PWR WINDOW BUTTON
BLUE LED FACTORY ROOF AND BOOT CURTESY LIGHTS
ALLOY GEER KNOB
FULL SET OF S2 MESH STYLE R33 FLOORMATS
CARPET,SEATS,DASH INTERIOR IS IMMACULATE
AIRCON/CLIMATE CONTROLL
ABS BRAKES,DUEL AIRBAGS,POWER WINDOWS,MIRRORS ETC
ENGINE IS WELL LOOKED AFTER WITH MINIMAL BOLT ON MODIFICATIONS,FLUIDS ARE CHECKED EVERY WEEK.
JUST HAD MAJOR SERVICE DONE WITH TIMING BELT REPLACED FULL INSPECTION OF ALL SUSPENSION AND BUSHES, REPLACED BOTH TIE-ROD ENDS, CHANGED ENGINE OIL WITH MOTUL FULL SYNTHETIC AND CHANGED FUEL AND OIL FILTER, NEW IRIDIUM SPARK PLUGS AND CHANGED DIFF AND GEARBOX OIL WITH NEW REDLINE SHOCKPROOF OILS, NEW TAPPET GASKETS, NEW INTERCOOLER HOSES AND BOOST LINE HOSES.
ITS MAKING EST 280-300RWHP AT 14PSI, AS I ONLY DRIVE IT ON WEEKENDS I RUN A LOW 10PSI FOR BETTER DRIVEABILITY(even with new tyres it breaks traction and steps out everytime you give it a bit),BUT STILL BREAKS TRACTION AND STEPS OUT JUST RUNNING 10PSI.
NICE COLD AIRCON,EVERYTHING WORKS BAR THE AUTO ANTENNA AS I HAVE DISCONNECTED IT(LOOKING LIKE A REMOTE CONTROLL CAR)
ONLY BAD BITS ARE THE DIFF IS PRETTY TIGHT(CAN FEEL WHEN PARKING OR SLOWLY TURNING)PAINT HAS 1 SMALL IMPERFECTION ON DRIVERS DOOR,AND THE RIMS HAVE SOME RASH SO ITS NOT A SHOW CAR BUT STILL AN AWESOME R33.
REGO TILL AUGUST,RECENTLY PASSED RWC NO DRAMAS SO CAN PASS ANOTHER ONE EASILY IF NEEDED,GHT70 PLATES NOT INCLUDED.
PRICE- $14200neg
Pm
msg 0401228867
or email- [email protected]
Thank you.
https://www.sau.com.au/forums/topic/366833-97-r33-s2-40th-ann-edition/
Just installed new tappet gaskets $77, also cleaned the throttle body,iac valve and tps sensor. Tappet covers and intercooler pipeing all black now. I'll be relocating the oil catch can tomorrow to the back of the engine bay as its a bit in the way.
  • 3 weeks later...
    • Executive Committee roles: President - Andrew Collins Vice President - I’m happy to continue  Secretary - John Richo Treasurer - Martin Sullivan
    • Hey I get it. Definitely sounds exciting, but not for me, there is almost no V10 or 12 that I really like. I don't like big engines with high cylinder count. V8s would probably be where I draw the line of "which engine would you use". Specifically an LS7 is a favorite of mine, or the 5.2 Voodoo by Ford.
    • But V12 Skyline. Like, I'm In!   Stay Tuned in the USA are jamming a V12 into a Foxbody at the moment... Just the sound of V10 or V12 is worth that adventure!
    • To put it in perspective; there is just one tuner shop that sells a single turbo kit for the RB26, at least publicly in their shop. Maybe one or two others can offer you a setup if you inquire, but I am not sure. That turbo kit is 16k in parts alone (high quality ones, but still). By the time it's installed, tuned and legalized expect it to cost 25k+. And then you still didn't take into account for any special wishes. I can't imagine legalizing an LS swap for example to be any cheaper. And if you want to legally raise power output by more than 40% of the highest-powered OEM variant of any specific car you'd have to do stress testing on a race track for 2000km. Wildly out of perspective cost and effort wise, especially for just one vehicle. But if you got too much money, I guess you could do it.
    • Yeah, I understand that TÜV is a bitch, but.... cost is not an issue when talking about putting a massive NA (or possibly large + turbo'd) V engine into a Skyline. We do it because it is fun. If mine was a project car and not a daily, I'd be finding some massive engine to put in it. Possibly one of the Toyota V12s that they make into monsters in New Zealand. Engineering is not cheap and easy here either (although definitely easier and cheaper than in Der Vaterland). But anything is possible, and 7L is better than ~2.5L, by about 200%.
