letemlaf Posted March 19, 2004 Share Posted March 19, 2004 i recently bought an r33 gtst with a brass button clutch installed, what are the advantages of this kind of clutch? i havn't heard much about them Link to comment https://www.sau.com.au/forums/topic/36685-brass-button-clutch/ Share on other sites More sharing options...
gtrken Posted March 19, 2004 Share Posted March 19, 2004 Bites harder when launched but can shudder . If it is cushioned button and sprung centred you wont even know it's in there. If it's flat plate and solid centred , it will probably shake the fillings out of your teeth if you get the take up wrong. Cheers Ken Link to comment https://www.sau.com.au/forums/topic/36685-brass-button-clutch/#findComment-732259 Share on other sites More sharing options...
letemlaf Posted March 19, 2004 Author Share Posted March 19, 2004 cool can shuddering damage the gear box or anything else at all? Link to comment https://www.sau.com.au/forums/topic/36685-brass-button-clutch/#findComment-732284 Share on other sites More sharing options...
gtrken Posted March 19, 2004 Share Posted March 19, 2004 cool can shuddering damage the gear box or anything else at all? Not really , just drive you and your passenger nuts. If it's really bad , there may be a problem with a warped plate but as long as you can engage reverse of first while stationary , then it will be ok. Cheers Ken Link to comment https://www.sau.com.au/forums/topic/36685-brass-button-clutch/#findComment-732294 Share on other sites More sharing options...
resonance Posted March 19, 2004 Share Posted March 19, 2004 I have one in my 180sx - it's annoying in peak hour traffic, but I hate and avoid peak hour traffic at all costs anyway But it's good for drifting (not what I do but I've been at the Skidpan day and it helps with its bitey nature). Apart from that after a bit of wear, they arent that bad .. mine shakes only a little beacuse I have found a point where it grabs slightly, like a normal clutch (and doesn't shudder) and then once the car is moving then let it go and it shakes maybe twice and then its fully engaged. As for damage, I don't think they are too bad, but I have heard from people that these clutches are 'brutally honest' in the way they work - they can put a bit of load on the flywheel/gearbox/dif, but I don't think it's too bad. You'll get used to it mate Link to comment https://www.sau.com.au/forums/topic/36685-brass-button-clutch/#findComment-732520 Share on other sites More sharing options...
