got a few questions about my RB30 TWIN CAM;
1/ going to be running E85 and going into the 400rwkw territory looking at 2000cc injectors - bosch 2000cc's? OR Injection dynamics 2000cc's? which one should i get?
2/ looking at getting aftermarket pulleys. but i am running Rb25 Ross harmonic balancer with Rb25 power steering pump/rb25 alternator & rb26 N1 water pump. can i purchase an off the shelf pulley kit for this? are rb25/rb26 pulleys the same?
looking at this http://www.ebay.com....=item27ba6a17ee
3/ im running a GTX35 T4 1.06 turbo on 6boost mani - for my exhaust im getting made up a 3.5inch dump to 4inch cat back? is this ok or should i keep it 3.5inch the whole way?
thanks guys,
Edited by BMYHOE
https://www.sau.com.au/forums/topic/366859-few-questions-about-my-rb2630-setup/
1 get ID's unless you can flow match the bosch injectors. ID1000 should be ok for only 400 rw kw
2 pretty sure RB26 use different pullies to RB26. Water pump and alternator should line up at the very least but the power steering wont
3 4'' all the way minimum. Finding good 4'' mufflers is a prick as they are all expensive, if you have to step down do it after the diff. You can also split it into a duel system but
there isnt always enough room
yeah just after some head room on injectors for later on so ill do the id2000's
ok i might just keep with standard pulleys just in case there are any problems.
with the exhaust i was looking at getting a custom muffler made so i can keep the noise minimal. also looking at the varex muffler. - thoughts on that?
Magnaflow make 3.5 and 4" mufflers, reasonably priced from Summit. 3.5" should be more than enough for 400rwkw with an open wastegate, but that being said 4" is a more common size so the bends tend to be easier to find and for that reason cheaper as well (I had a great deal of difficulty sourcing 3.5" bends).
I had my bosch 1600's flow tested with almost no measureable difference (less than 1/3 the price of ID's). You can be reasonably sure the plenum will be responsible for much larger variations than the injectors so if this is a major concern run an ecu capable of trimming fuel delivery to individual cylinders and run an egt on each exh manifold runner.
ok good to know, with the injectors ive been doing some homework and found most guys are using the id2000 which are ment tobe good for smooth idle etc..
was thinking 3.5inch dump then 4 inch cat back.... muffler im probly leaning toward varex for noise control when needed
There is a fair difference between the ID1000 and ID2000cc injectors in terms linerarity at the on opening time required for a closed loop idle. I have tryed tuning ID2000 on an EVOX(which will have almost identicle fuel requirements as a RB30) with the factory ECU and had issue getting to a closed loop idle even wtih e85. If you have a decent ECU make sure you set your min on time to around 1.5ms and just let it go rich. Make sure you get your dwell times correct which isn't allways the same as what is supplied with the injectors.
im using a haltech p2000 the lastest one, and with the tuning im going to a repuable tunner in sydney that is know for Rb30's etc.
also with the wideband 02 sensor should i put 1 or 2 in the dump pipe?
Best tuner in the world ain't going to be able to tune around the wrong combination of parts - I would run it by him b4 buying injectors.
yeah I wouldn't be so sure. I'm using ID 2000's (which are actually 2225cc) making 400kw on E85 @ 65% duty cycle. That's on a 2.8 with twin RS's. The idle is better with these than my old Sard 800's.
ok i will double check with them but there seems to be lots of guys using them without any dramas
Thats shite - By my calcs for a normal engine 2000cc injectors @43pi base pressure@65% duty you should be making making 650kw @ the wheels on a dyno dynamics dyno.
You've obviously got something wrong there. BTW most engine idle better with a richer idle.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
    • Turn it into the pride flag
    • I think you'll find we're confused about what you were trying to do and how you were doing it. I would have thought that block rigidity was something you measured while loading the block in beam or in torsion, and that you would do so before and after grout filling, to see if putting material in there created a "composite" construction with the expected rigidity increase. Notwithstanding that the true function of grout is less about gross rigidity than local (ie preventing bore deflection/splitting and tying the bores to the main bearing locations a little better, etc etc). It is nearly impossible to follow your description of what you've done without closing ones eyes and making "aliens" hand shapes in front of oneself to try to follow the manipulations you've made. It's still unclear to me what you were trying to prove.
