Varex Exhuast
Basically fited a 3.5inch exhuast to my 33 with 270rwkw and its got a valve inside the exhuast, its the dodgy version of the varex
the exhuast is only sort of quiet when the valve is fully closed, but the gases hav no where to go.
Is it ok to drive around like this to get less attention or is the pressure to high? ( il be driving under 3000rpm)
What do you mean dodgy version? Is it a Varex or a knock off? Or one of those Apexi sandwich valves?
Its a knock off
its a butterfly valve in the exhuast and when its closed its like putting your hand lightly over the exhuastvpipe to slow flow
its still got lots of flow i imagine becuase its stillso damn loud but lags like all hell when closed
Car still starts up fine when valve is closed fully
( i imagine even when the valve is closed fully its not the same size as inside diameter of pipe i.e. Its a 3inch valve mabye, or it dosent close completly)
cheers
Its a knock off
cheers
Yes I know what a Varex is I have one, I'm saying where in the exhaust is the valve? In the end muffler like a Varex or half way along the exhaust like the Apexi wunder valve? Varex use recirculation through a smaller hole that leads into another muffler...it's a much better/safer design when closed off than the Apexi valve. Either way it should be fine, just avoid boosting and high RPM.
you can drive around with it closed up as long as you arent accelerating hard. it does restrict your exhaust flow a fiar bit, but if you take it easy it will keep you out of trouble :thumbsup:
Are you going for an EPA test? No mufflers will be illegal noise-wise, even with that valve. The standard system is 88 decibels and the legal limit is about 90 :/
Nah im not but im in traffic very often and seem to have undercovers behind me often, just need it to sound relatively stock
iv got a catback stock systen with 3.5inch flange to bolt straight on for regency if need be but in that case id be screwed from supporting mods and suspension
 Share
