Hmm, not gonna be an easy, quick fix. Anyone know the best place to get vac hoses? Are there any tips u guys can give me for the process? Seems like most of them are gonna be hard to get to. Bosszilla, what do u charge by the hour? ;)
  • Replies 180
dude after doing an engine swap after having a big end go there are a f load of hoses you wont even realise are vaccume lines, two of which are hard up against the fire wall and there is no way in hell you can do them without pulling the motor out
i wouldnt mind hearing the issue your having cause it sounded like at first the problem mine had which was the alternator had gone so the car would get absolutly no power and ran rough as hell. but if its still starting then i guess that's not the issue other wise your battery would be dead by now
oh yeah nothing to be proud of but i just got made redundant to im not too busy atm till i get replacement work so i can come have a look too if your keen on any help ill bring my bastard child too (being my gtr)
Starts after a few engine turns but then sounds like it's gonna stall. There is also quite a loud tappetty sounding ticking noise that I don't remember coming out of the engine bay.. I have the manual including the vacuum setup and as you say, there are two I can't even really see.
What do you all recommend?
I'm going to check the vac lines I can get to and with any luck i'll find an easily accessible leak that'll solve my immediate problem so I can get it to a 100k service. :)
Jesse.
Nak, I'm totally free this arvo if your close by and it's not too much trouble. It'd be good to get another persons take on it before I go back to work.
My poor car hasn't moved in a few weeks now. :(
Had the same problem. Except mine was slightly worse. Haha had a head gasket go. Instead of getting a new top end with a shit bottom end and a load of kms still I jus thought ill buy a new motor all together.
Don't say that Ninja.. :P
Maybe next step is to try someones afms that are known to work. Any hands up? Hehe.
I really hope it's not gasket.
I'll check what time I have this week coming and hopefully I can book one of you guys in for an inspection. :)
Cheers guys, much appreciation for your time.
Jesse.
right put on a bbq and we all come over. Not saying we will get anything done but i cant resist a bbq. MMMMM bbq.
Serious, should have a few hours sat arvo more than happy to pop over with my tools a give it a go.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
