  • Replies 180
Well all the normal stuff appears to check out OK, I think Ross checked the fuel pump too.
The gaps in insulation on the wires of the CAS plug didn't fill me with a lot of confidence.. neither did the butchery at the ECU plug end!
ok well dat suck's well at least u know thow's bits work
well it's worth a try changing it over. see if u can find some1 with a spare loom and ecu.
if all good then u can buy with out worrying about wasting money.
what ever it is i think its some sort of electrical prob. just going to take time to work out
the pump was priming but i didnt check fuel pressure, dont have a gauge.
its just one of those fun electrical problems :rolleyes:
Shame about the fuel pressure test, I still think it is a poor earth with the FPCM (fuel pressure control module).
Especially if the looms have been butchered.
Solder/twist on a wire from the fuel pump earth to the body of the car and let me know what happens so i can sleep easier :P
bogan way of testing if fuel pressure is causing the problem (assuming theres plenty of flow from the pump) is to slowly clamp the return line with some pliers (fat ones so you dont damage the line) and see if it improves.
otherwise theres a fairly cheap fuel pressure gauge on just jap that'll come in handy more than you think. i'd lend you myne but some prick smashed it up
Well I dunno, I just resealed the four split wires and took the bigass battery outa my V8 to try but still no good.. I can't help but think we'v overlooked an important factor, when the keys are turned to 'power' in the ignition, u don't hear the fuel pump prime, or if it is, it's alot quieter. Back in the day(a few weeks ago) you would hear it buzz loudly for a good 4 or 5 seconds. What could this mean?
Oh, and it's got worse, Mike. A struggle to even start now.. :'(
Edited by V8or4X4
I havnt tried swapping a working fuel pump in yet, knight. I also better stress the problem has taken the car from fine to unstartable in the space of 12minutes gentle running time. :s
It turns over and after 6ish seconds it starts coughing like it wants to start, a few secs later it might start and as Bubba said, runs like a tractor..
I would try pump. it sounds like it might not be getting fuel.
My stagea dose not like starting first time in the morning and i am shore its to do with low fuel pres. When i started it in the morning it would fire and run but run like it was missing or not getting enough fuel then stall. after i start it again or give it a rev it comes good.
So i have fitted a 040 and it is a little better but still run's bad for about 10 sec's before the rev's pick up. I have a hks fuel reg i will be fitting soon as 1 of the stock 1s might be bad
runs like a tractor maby it thinks its a sr lol
Edited by whitenight27
It could be the fuel pump itself or it could be the wiring the ECU to the FPCM.. the exposed copper near the ECU was worrying.. as was the exposed copper on the CAS wires..
How'd you go fixing the wires Jesse? I wouldn't bother chasing other things like actual fuel pump etc until you know the wiring is all good..
how did you fix the wire? just put tape over them? The thing you need to check is if the cover is cracked that the copper inside is not as well. If may look fine but use the multimeter to double check.
Again more than happy to help but with weather and stuff need to do it in a shed as we will remove alot of stuff from the car.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
