Hey all,
Next happylaps session is confirmed!
Date: Sunday July 10th
Same meetup place at Hypermarket car park, Aspley.
Departure from there will be at 3:30pm SHARP.
On track cruising from 4:30 to 5.00 with an evening meal to follow.
Steak and salad BBQ buffet
Selection of bread rolls
Rump steak
Chipolatas
Sauted Mushrooms
Garlic potato bake
Tossed Salad
Coleslaw
Payment is on the day
Members: $35
Non-Members $40
https://www.sau.com.au/forums/topic/366906-lakeside-happylaps-sunday-july-10th/
  • Replies 109
The list so far guys and girls :thumbsup:
1. Me
2. Spr34
3. Fineline
4. Boz
5. Smity42
6. Bunta +1
7. Traditimeour
8. Dan B
9. Twocents - Poss +'s
10. Arebees13
11. Sabbai
12. v8skylineman
13 .Astrotristan
Updated :nyaanyaa:
1. Me
2. Spr34
3. Fineline
4. Boz
5. Smity42
6. Bunta
7. Bunta's +1
8. Traditimeour
9. Dan B
10. Twocents - Poss +'s
11. Arebees13
12. Sabbai
13. v8skylineman
14 .Astrotristan
15. Hypnotoad
16, Hypnotoad's +1
17. Hypnotoad's + 2
Updated :nyaanyaa:
1. Me
2. Spr34
3. Fineline
4. Boz
5. Smity42
6. Bunta
7. Bunta's +1
8. Traditimeour
9. Dan B
11. Arebees13
12. Sabbai
13. v8skylineman
14 .Astrotristan
15. Hypnotoad
16, Hypnotoad's +1
17. Hypnotoad's + 2
Count me in!!!!!
Just a little background for the newcomers, on what happy laps ARE and what is acceptable behaviour :thumbsup:
No helmets are required, because the idea is there is no real DANGER of personal injury on track
Speed around track is around 110KPH, 160KPH is acceptable on the STRAIGHT (this is what we were told last time, whatever the marshal says on the day goes)
Overtaking is to be either on the straight in a sensible manner or when the person infront waves you past them at a suitable time (no indicators are to be used, and they are to be ignored to avoid confusion)
No excessive traction loss i.e drifting, tailgating, dangerous manouvers or overtaking will be acceptable.
Stick to these rules and you will have an awesome time, if not then you may have infectious rangas set upon you (sorry colin) :nyaanyaa:
List has been updated, this now brings us to around 20 cars, and there WILL be a limit on numbers so get your name down asap if your coming :thumbsup:
1. Me
2. Spr34
3. Fineline
4. Boz
5. Smity42
6. Bunta
7. Bunta's +1
8. Traditimeour
9. Dan B
11. Arebees13
12. Sabbai
13. v8skylineman
14 .Astrotristan
15. Hypnotoad
16, Hypnotoad's +1
17. Hypnotoad's + 2
18. Pureplaya
19. Sneakey Pete
1. Me
2. Spr34
3. Fineline
4. Boz
5. Smity42
6. Bunta
7. Bunta's +1
8. Traditimeour
9. Dan B
11. Arebees13
12. Sabbai
13. v8skylineman
14 .Astrotristan
15. Hypnotoad
16, Hypnotoad's +1
17. Hypnotoad's + 2
18. Pureplaya +1
19. Sneakey Pete
Can everyone with +1's ect please specify if they will be driving around track or if they will be passengers. That way we have a better idea of how many cars are going to be on track :cheers:
1. Me
2. Spr34
3. Fineline
4. Boz
5. Smity42
6. Sho Pi
7. Fomby639
8. Traditimeour
9. Dan B
11. Arebees13
12. Sabbai
13. v8skylineman
14 .Astrotristan
15. Hypnotoad
16, Hypnotoad's +1
17. Hypnotoad's + 2
18. Pureplaya +1
19. Sneakey Pete
1. Me
2. Spr34
3. Fineline
4. Boz
5. Smity42
6. Sho Pi
7. Fomby639
8. Isola +1
9. Dan B
11. Arebees13
12. Sabbai
13. v8skylineman
14 .Astrotristan
15. Hypnotoad
16, Hypnotoad's +1
17. Hypnotoad's + 2
18. Pureplaya +1
19. Sneakey Pete
20. Boiracer
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
