landrovers have improved much over the years but they still have their problems: electrics being the main
service is very dodgy from dealers as they will overcharge and leave certain things out: replacing brake pads but not machining discs, not reseting service indicators etc
buy from a dealer as they will offer a warranty and always purchase an extended where applicable.
range rovers are great cars, excellent to buy second hand as they depreciate and you can buy a few year old sport for almost half price from new.
I am thinking of buying a Range Rover Sport TDV6 as a second car, has anyone had any experience with this car? Its engine block is made of cast iron whereas the V8 versions made of aluminium. Any comment on its reliability, cost of maintenance, etc is appreciated.
Cheers
My old man is looking at getting something similar.
they have to be the most comfortable 4WD on the market, however you should shop around, make sure you bargin hard.
If you want to compare it to something go and test drive the Volkswagen Toureag. V6TDI or V10TDI, for what you get in terms of options they are very very generous. like Reverse camera, SATNAV, heated seats, sunroof, tow bar. 20 inch wheels.
Have you driven a BMW X5? I just bought a new Land Rover Discovery 4
for my wife ( I know thats not a Range Rover but there must be a lot
of crossover gear) The biggest difference I noticed from the X5 ( I
have had a number of BMWs) is the ride is much nicer in the land rover.
If you want a smooth comfortable ride and like the boxy look, then
Range rover is nice car.
Personally I dont like the steering/handling or throttle response compared
to the X5. The Beemers are so much more sporty, handle better and because
they are about 400kgs lighter they just blow the rovers into the weeds!
My 2c
They apparently also have a habit of engine oil tracking down the loom and crapping out the ECU.
lolz not sure about that one but the rear tailgate switch went after only a few years + rubber components in the suspension crack quite often and need to be replaced - this is for a discovery 3 though
Yes.
My brother's owned a Disco 3 for about 3 years now and it's a pig. We all advised him against it (including my bro-in-law who used to sell them brand new but gave up the agency because the warranty repairs were sending them bankrupt). The Disco has been in the shop more times than I can count, and has left my brother stranded a few times.
I wouldn't touch anything with the name rover in it. THey may be better than they were, but they are still big steaming piles of poo.
^^^^this man knows
And it all depends on what you want to do with it.......a suburban cruiser, who cares buy whatever you like, VW, Rover, X5, Jeep, Cayenne blah blah..........a real workhorse real 4wd, buy a Lancruiser, Hilux, Dmax, Colorado, Prado etc etc doesn't matter how the leather seats feel or good your ride comfort is if it stops and doesn't go between Camerons Corner and Alice Springs, you'll end up like Burke and Wills.
  • 3 weeks later...
I went to test drive one "sport" awhile ago , and these are the thing that happened on the test drive.
The ABS failed and intermitently cut in. seat will not move fore or aft, and the after thee test drive
it refuses to lock up. just kept on poping open after u hit lock.
apart from that, it is a sexy looking "true 4x4"
now I'm driving a Q7.
I dont think my legs are capable of pushing one of the highway.
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
