SHORT NOTICE!! Group buy EXEDY CLUTCH KITS!!!
  • Replies 51
FARK!!!!
I go out and spend craploads on a clutch and then EVERYONE starts offering them cheap!
/rips hair out/
I got an Exedy Extreme, 6 button clutch [pull type] - 43% stronger than standard...Price from daikin was approx $750 - please tell me you cant get them cheaper than that? [via pm]. Thanks
I doubt it. How could they be exactly the same, when you have a 32?
btw 32 and 33 gtst parts and prices are NOT the same!
its the same clutch u spastic but for the 32 :D
pricing wont be that much different
The price from Daikin [Trade Price] is $750 for the part you spastik...+ tax + profit margin + markup + tax + remove + refit :D
Is yours a "pull" or "push type"? Do you actually know [i wonder]? :P
"Push" type is always cheaper...
Yours should be "push" based on the fact most rwd 32,33 AND 34's are...only early model 34's likke mine are Pull type - same as 33 / 34 GTR - and are stronger / more expensive to begin with...
end :P
lmao u spastik... i dont know... all i know is benny put it in for me before his shop opened up and the price i got was basically cost price without install costs :D
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
