SHORT NOTICE!! Group buy EXEDY CLUTCH KITS!!!
  • Replies 51
FARK!!!!
I go out and spend craploads on a clutch and then EVERYONE starts offering them cheap!
/rips hair out/
I got an Exedy Extreme, 6 button clutch [pull type] - 43% stronger than standard...Price from daikin was approx $750 - please tell me you cant get them cheaper than that? [via pm]. Thanks
I doubt it. How could they be exactly the same, when you have a 32?
btw 32 and 33 gtst parts and prices are NOT the same!
its the same clutch u spastic but for the 32 :D
pricing wont be that much different
The price from Daikin [Trade Price] is $750 for the part you spastik...+ tax + profit margin + markup + tax + remove + refit :D
Is yours a "pull" or "push type"? Do you actually know [i wonder]? :P
"Push" type is always cheaper...
Yours should be "push" based on the fact most rwd 32,33 AND 34's are...only early model 34's likke mine are Pull type - same as 33 / 34 GTR - and are stronger / more expensive to begin with...
end :P
lmao u spastik... i dont know... all i know is benny put it in for me before his shop opened up and the price i got was basically cost price without install costs :D
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
