Hi Everybody,
have most parts available from a wreck i bought a while back,
All located in adelaide SA, cheap give away or bonus lots with purchases. (does it sound like a haggle co sale????):action-smiley-069:
Car WAS a 2 door manual turbo, with side damage,
have all interior plastic trims, bits & pieces available
dash assy, seats front & rear, parcel shelf, consoles, carpet,
tripple gauges nismo and std,
have suspension, brakes and driveline parts,
exhaust (cat-back) stainless steel
rh clear front bar indicator
LH door assy complete
LH rear 1/4 panel cut
door rubbers and trims
boot lining & carpet
have genuine garage IMPUL side skirt LH side, & damaged front bar (missing rh cnr) in white
also RH side skirt from altia or nismo kit, (not sure)
plenty more, all on racks / shelves.
lets just say $10 for most parts, if you need more than 1 part ill chuck other gear in FREE, this gear has to go,
bigger bits, make an offer or negotiate a bargain
all parts in adelaide and pickup preferred, however will pack & post @ your expense.
pics available of items upon request, have taken alot of pics already.
email or PM for furthar contact detail
"""""neon6 @t adam dt com dt au"""""""
Edited by nat0z
  • Replies 76
Hi Mate.
1. Steering Wheel? Non-automatic?
2. Also, a right side rear reversing light in the bumper bar (not the body) - white. Some R34's have a white light, some have a red light in the rear bar.
If so, some pix will help.
Rgds ... Les 0417 123 053
Hi Everybody,
Whats happened to all chasing the nismo tripple gauges????
any offers that are willing to post cash to confirm the sale? lots of BS from many teen'e bobs maybe??
may just end up on ebay
Edited by nat0z
front & rear???
will post up tonight
nat0
Im assuming the rear seats for the 2 door are the same as the 4 door? If they are then yes.
Im looking to replace mine because front and back are badly stained.
How much are you looking to get rid of them for?
    • Holy hell! That is absolutely stunning! Great work!!!
