yea cheers, bud.
need to get in contact with bloke chasing the tripples cover only.
as i think i finally have someone actuall keen on the nismo's only (hopefuly)
so may now have the cover ready to rock.
nat0
  • 1 month later...
  • Replies 76
hey. pm me the price of the trpple gauge cover.. im after one now if its a good price. if its pickup im there now.. thanx may take hte nismo gauges as well, thanx
  • 2 months later...
Hi
Sorry if I have asked before I am after the latch attached to the boot, if you still have it how much and has it had any damagedamaged.
Regards Taylor
0408188777
hey mate, have u got the nismo tripple gauges still? i got $ atm so if u want to give me a price and its reasonaly i'll take it off ur hands asap.
Hi Everybody,
have most parts available from a wreck i bought a while back,
All located in adelaide SA, cheap give away or bonus lots with purchases. (does it sound like a haggle co sale????):action-smiley-069:
Car WAS a 2 door manual turbo, with side damage,
have all interior plastic trims, bits & pieces available
dash assy, seats front & rear, parcel shelf, consoles, carpet,
tripple gauges nismo and std,
have suspension, brakes and driveline parts,
exhaust (cat-back) stainless steel
rh clear front bar indicator
LH door assy complete
LH rear 1/4 panel cut
door rubbers and trims
boot lining & carpet
have genuine garage IMPUL side skirt LH side, & damaged front bar (missing rh cnr) in white
also RH side skirt from altia or nismo kit, (not sure)
plenty more, all on racks / shelves.
lets just say $10 for most parts, if you need more than 1 part ill chuck other gear in FREE, this gear has to go,
bigger bits, make an offer or negotiate a bargain
all parts in adelaide and pickup preferred, however will pack & post @ your expense.
pics available of items upon request, have taken alot of pics already.
email or PM for furthar contact detail
"""""neon6 @t adam dt com dt au"""""""
Do u have & how much for (R34GTT):
- front & rear struts (plus rack rods & tie rods
- power steering rack
- clutch
drip moulds for r34 coupe.... there on the exterior of the car over the side windows... they join the quarter windows an some have those visors with them.. if u have how much posted to 3756
- clutch
hi mate i am really interested in the door rubbers and trims and was hoping you also had the cover that sits around the gear stick as mine is stuffed...
have u still got the front seat?
thanks mate
  • 1 month later...
    • Holy hell! That is absolutely stunning! Great work!!!
