There's nothing more sexy than a chick driving a liner :P
Btw I like 20's on a car, everyone has their own taste in cars so just customize it the way u want it. Might get afew haters but asif their opinion matters lol
HAHA.. yeahh i highly agree
hmm i dunno every turned me off 20's soo ehh not too sure
next goal.. is she should b turboed pretty soon :)
are you using a turbo gearbox or the stock natro one? if the stock one then expect it to break if you up the power. also does your car have a lsd or are you putting one in? if not then expect to get wheelspin unless you have good quality tyres (especially in the wet).
hey matty flynn im sure i shore i sore your car at eastern creek last nyt... dnt no if u rember me but i had the purple 32 wen went 4 cruise 4 kids..... i dont rember that dint in the back bumper though lol
quick question, do you close your eyes when you type?
yeah i do pretty much
i also like to see how you show new members how we treat each other...
i have met alot of nice people on these forum but there are them few that just want to try to insult people for no reason
i think people like you that have no respect and obviously dont realy have a life should hold there breath and die... there is
no space for people like you in this county..
did you understand that????
Edited by smcqueen89
you also have to remember that you are not in a serious section of the forum. had you posted in the tech section asking for help i would've been more than happy to help, unless you had asked a question that gets asked every 2 days, in which case i, and many others would've simply told you to use the search function. in time you too will become one of those people too, as you will start to find out just how much some questions get asked and you very quickly get sick of seeing them posted.
LMFAO at above exchange.
not wanting to exacerbate things by flaming people who seem to type without taking their driving gloves off but it do find it a lot harder to read said posts, something to do with having to correct every other word in my head for spelling/grammar and by the time I get to the end of it I have forgotten whatever point the poster was trying to make.
or is this just me and my short attention span?
anyway came in here to welcome the new girl with the silver R33 which going by the pics looks exactly the same as mine! good stuff and hope to see you at a cruise, trackday sometime soon. The best part about SAU (other than the wasteland of course) is being able to participate in events and meet like minded people with a passion for their hobby :)
Well i still havent driven her as i have no licence... . i get it back on the 29th september and cant wait !!!..
im looking forward to the events, as my brother is with the supra club n usualii takes me out with them it looks like alot of fun.. except well there supras hahaha
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
