There's nothing more sexy than a chick driving a liner :P
Btw I like 20's on a car, everyone has their own taste in cars so just customize it the way u want it. Might get afew haters but asif their opinion matters lol
HAHA.. yeahh i highly agree
hmm i dunno every turned me off 20's soo ehh not too sure
next goal.. is she should b turboed pretty soon :)
are you using a turbo gearbox or the stock natro one? if the stock one then expect it to break if you up the power. also does your car have a lsd or are you putting one in? if not then expect to get wheelspin unless you have good quality tyres (especially in the wet).
hey matty flynn im sure i shore i sore your car at eastern creek last nyt... dnt no if u rember me but i had the purple 32 wen went 4 cruise 4 kids..... i dont rember that dint in the back bumper though lol
quick question, do you close your eyes when you type?
yeah i do pretty much
i also like to see how you show new members how we treat each other...
i have met alot of nice people on these forum but there are them few that just want to try to insult people for no reason
i think people like you that have no respect and obviously dont realy have a life should hold there breath and die... there is
no space for people like you in this county..
did you understand that????
Edited by smcqueen89
you also have to remember that you are not in a serious section of the forum. had you posted in the tech section asking for help i would've been more than happy to help, unless you had asked a question that gets asked every 2 days, in which case i, and many others would've simply told you to use the search function. in time you too will become one of those people too, as you will start to find out just how much some questions get asked and you very quickly get sick of seeing them posted.
LMFAO at above exchange.
not wanting to exacerbate things by flaming people who seem to type without taking their driving gloves off but it do find it a lot harder to read said posts, something to do with having to correct every other word in my head for spelling/grammar and by the time I get to the end of it I have forgotten whatever point the poster was trying to make.
or is this just me and my short attention span?
anyway came in here to welcome the new girl with the silver R33 which going by the pics looks exactly the same as mine! good stuff and hope to see you at a cruise, trackday sometime soon. The best part about SAU (other than the wasteland of course) is being able to participate in events and meet like minded people with a passion for their hobby :)
Well i still havent driven her as i have no licence... . i get it back on the 29th september and cant wait !!!..
im looking forward to the events, as my brother is with the supra club n usualii takes me out with them it looks like alot of fun.. except well there supras hahaha
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
