Hi all...
I was driving home from the flicks earlier and my turbo started whining when it spun up past about 6 psi... so I'm figuring she's knackered?
I was on to a crowd before in England (cos there's nobody here in Ireland worth talking to as far as I know) and they said they can't recon the OEM unit. That leaves me with buying a new one or a reconditioned unit.
Will a Garrett T3 bolt straight on? there's plenty of them kicking around here because they came on Cossies so the lads in England know them well.
Or.. am I better off getting a second hand one from a breaker in Australia and reconditioning it?
Anybody got any recommendations about what to get considering I don't want to spend eleventy on one, the car is mildly modded (Apex intake, Dual N1 exhaust, Trust FMIC) so I don't need a truck turbo :D
I'd really appreciate any help guys!
ive just put an r34 turbo on my car and i cant complain, havnt had it tuned yet and my clutch just started slipping but it pulls so much harder right through to the top of each gear, might be a thought that or an r33 turbo if ur not looking to spend to much money.
Ive got a HKS 2530 (T3 flange) on mine, i need to get the computer replaced, or rechipped, because if i run over 12psi the AFM maxes out, but on 12psi in my RB20 i put out 212rwkw (280rwhp i think). it bolts straight onto the existing manifold and dump pipe, but you will have to make new oil and water lines for it. but thats not too hard, i went for braided lines, which can get expensive.
i would recomend this turbo to anyone with an RB20 who wants a perfect street car. you dont loose alot of bottom end, but get alot of mid and top end power gains.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
