  • Replies 41
Swaybars changed my life, I'd get them straight up.
Spacers to give you extra lock cost <$50 so deff get those, makes the steering quicker too.
Coilovers are good too if your budget will allow. (BC Coilovers are good for around $1200)
Shim your stock diff up nice and tight.
500ml extra oil is handy.
Get an alignment too, ever so slight toe in on the back to help keep it predictable and slight toe out on the front to sharpen up the steering.
Tune Agent castor rods are cheap too ~$250, helps the car self steer. But I think adjustable castor rods are illegal for street use? correct me if I'm wrong.
Try and drift with brand new tyres, then you can spend more time out there and less time in the pits changing them thumbsup.gif
My car felt like two bricks connected by some playing cards before I got the cage put in it. While you wont actually damage your chassis by drifting (lol FF) some extra bracing might help tighten it up a little.
Before you do any mods though, just get out there and try it! See if you really like it first! Just give it a go ;)
Tyres... just buy tyres and get some track time.
Don't buy tune agent anything! I watched 2 pairs of castor arms break/fatigue topoint of failure with in 6 laps of a track!!!
Tyres, tyres, tyres...
My tune agent castor rods have done a lot more than 6 laps and I've had many unfriendly encounters with the curbs and they still look shmick as. I'll admit the older ones for the Silvias look like dried spaghetti though.
And yes, tyres, lots and lots of them. I've had good results with admirals. Cheap and they wear evenly right down to the carcass and don't delaminate at high temps. the Federal 595-ss are also good.
Get ready to buy HEAPS of tyres. :D Buy brand new ones though, 2nd hand ones you'll just spend the whole day in the pits swapping them over.
+1 to track time too, any track time is fine, even if it's not drifting, you just need to learn how your car behaves on the track\at the limit.
steering rack spacers are win and cost next to nothing
What are these,where do you get them, where do they go and how do they work..? :D
  • 2 months later...
Where do you get those tierods that you posted simon?
You can get some Tien tierods from Cartel Aus - http://www.shop.cartel-aus.com/Tein-Tie-Rods-Tie-Rod-Ends-DWSS028.htm
I drift with just my stock 32, i just chucked in some tien coilovers and away i went, and it's handy to have good steer tyres. all the extra's just make drifting easier
Diff... welded works a treat
choppies or coilovers if u can afford them... more drift less sailing on the high seas
Seat if your picky...
Fuel
Lots of tyres
A smile for the camera and the pretty ladies watching you
Seems people get so caught up on what is done to all the high end cars and forget to go out and give it a go.
I started in my first 32 years ago with a shimmed diff and a set of coilovers. best time of my life, spent plenty of money on fuel, entry fees and tyres then went and bought a seat and camber arms etc later on as I improved and found the need.
GO SKID
Edited by ti2l
Alright,
I'm curious to see how a stock R32 reacts to sliding so I'll gradually add mods as needed.
This is how I think my priority list should look. I don't plan on buying everything at once or back-to-back so I'll see what the car tells me and upgrade as when I need to.
1) LSD - I'll probably get a 2-way diff as I'll use the GTS-T on the street and welds aren't daily driver friendly.
2) Sways- Adjustable only. I think Whiteline is the only company that makes adjustable sways for the Skyline.
3) Tie Rods - I'll be driving a '89 GTS-T so I'll probably buy whole replacement rods as opposed to just the spacers.
4) Harness (with stock seats) - Cassbo's suggestion. I'll try that first.
5)Clutch- A durable clutch
6) E-Brake- A durability to the E-brake (or upgrade)
7) Tires/Wheels- Brand New sticky tires up front and decent brand new tires for the rear. Extra wheels (maybe).
8) HICAS/ABS- Remove HICAS and/or ABS. I have my eyes on these: http://www.splparts.com/chassis-Z32.html#SPLHCKZ32
9) Suspension- Coilovers and supporting suspension parts.
10)Engine- PS cooler and more HP.
that's a mighty fine list you've got there son :)
Rack spacers should be on there too at #3.
Drift button too if you don't already have one.
Maybe a deep dish steering wheel too so you're not always slapping the wiper\indicators when you're throwing the wheel around. (that's if you have this problem)
  • 3 weeks later...
id be removing hicas sooner rather than later... will make life a lot easier
second hand tyres are fine for the rear... dont ned to be decent to get u started.. 595 or similar up front are cheap and work well
id also throw coilovers a bit higher up the list.... unless ur getting the angle grinder out ;)
u really wont need tie rods and rod ends till much later on, skidded for years in mine with stock tie rods etc.
stock handbrake is great... just get it adjusted
order should be:
Diff
Remove Hicas
Coilovers
skids
the rest can really happen whenever u progress and arent necessities to get you started..... stop thinking and go drive
yeah I've got the 595-evo on the front of mine, they're pretty good :) you want a slight stretch too to sharpen up the steering response. I upped my camber to -4 degrees too, changed my life.
Again, I have let the car tell me what needs to be changed..
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
