Four simple questions about boosting a RB25DET from a R33.
1, What is standard boost?
2, What is the maximum boost that the stock turbos can handle? (or what boost level should i keep it under)
3, If I have a pod filter, slightly bigger SMIC and turbo back exhaust with sports catalyser, what boost will it naturally creap up to?
4, Whats the typical bog standard R33 rwKw figure and what might it be with the mods from question 3?
Thanks all
https://www.sau.com.au/forums/topic/367031-4-simple-boost-questions-for-r33/
  • Replies 42
7
10
without a ebc/valve 8 maybe?????
140/160
I concur.
Do you concur?
The pod filter will be entirely useless and not help power goals at all. It will also greatly increase the "I've got a stock turbo that spools even when I am being overtaken up a hill by a corrola sound"....which is the most ghey aspect of any R33 GTST ownership experience.
If you get a good full exhaust, panel filter, R34 side mount then you will probably make more than 160rwkw, perhaps closer to 170rwkw (if it matters). If you plan on changing the turbo skip the R34 side mount step, and add a Front mount WHEN you install the larger turbo.
Edited by simpletool
OP, off topic, but love your avatar... brings back memories when i went to japan for a holiday ahhh...the food is cheap and awesome there!
I'd chime in, but everyone else has already answered your questions.
7psi
12psi
anyone's guess
140rwkw stock boost
Search IS your friend.
At what stage does it hit R+R or experience knock [without an ecu or bender]???? Don't answer, I don't care, its a rhetoric question.
Thanks all
The other guys have answered already, but mine atm has the mods you have listed on 3, and it hits 9psi naturally. Mine bog stock was 145rwkw (huge lol) but not sure what it is with the extra small mods. I have to tell you though that you need to count in getting your ecu remapped or go aftermarket. Mine hates anything from 10psi, and runs with flat spots etc. Im leaving my boost controller off until i get my ecu remapped for that exact reason.
ok thanks helpful people, smart arses, well you know what your good for.
Im spending most of the budget on non-engine modifications which is why im keeping it simple.
BTW, what is R&R? Im guessing it aint rest and relaxation
Nothing wrong with a nice induction sound - it keeps things lively and entertaining.
The stock airbox is wank, it is massive and taken up loads of engine bay space as well as looking like cr@p. I'm all for say an ARC airbox but f**k the OEM offering right off.:thumbsup:
As for running a side-mount with 12 psi on the stock turbo I don't think that is very good advice at all, especially in a hot country.
Only a fool would buy an R34 SMIC especially if they are gonna get a bigger turbo later.
I went up to 12 psi on the standard ECU and it was pulling timing and the torque curve looked like a crinkle cut crisp side-on.
I had 3" 'zaust, sports cat, FMIC, POD filter.
But also a hard intake pipe and I cut the mesh off the inside of the AFM.
It made 206.5 rear wheel Kw's on a custom tune with dragging rear brakes so was obviously flowing very well with all the intake and 'zaust mods.
R and R is where the ecu sees too much flow from the afm and changes the timing and the fuel mix the keep the engine "hunky dory". Turn the boost up to about 13 or 14 psi and the stock ecu wont like it and will give you a scare . But smartarseness aside I have tried what I said earlier. The turbo didn't break and the car went like a cut snake. But still, don't try it tho...I have run 14 to 15 psi for the last few months and its fine so far. I don't flog it incessantly and don't let it get very hot from extended wot. To be safe stick with what the other guys have said..10 to 12 psi. Don't waste your time upping the boost over 10 psi till you get an aftermarket ecu tho. It will r and r and feel like crap to drive with poor economy :yes: Oh and don't cut the mesh out of your afm...It helps with air turbulence
R and R = Rich and Retard - ecu dumps more fuel in and pulls tiiming severely to protect engine - you'll know all about it - sudden loss of power and yes get a high flow panel filter for your stock air box.
Pretty sure I was answering this ^^ question when I said 12psi.
If the question was.....what is the highest boost I can run with stock ecu before R&R? or what is the maximum boost I should run with a SMIC? then somewhere lower would be advisable.
That mesh in the afm is actually there for a reason. I believe its to straighten out airflow before it reaches the resistor wire so it can take an accurate reading. I dont think its really necessary to remove it when it hasnt actually been proven to be a restriction.
Plenty of people have made alot more power with it still intact.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
