Hey guys, About a month or so again i replaced the upper outer control arm bushes on my R33 gtst. but i've noticed that the creaking sound is still there so i'm thinking it may be the inner bushes.
now it probably would have been a smart thing to replace those at the time i did the outer ones, but didn't think that far ahead.
my question is: does it matter if the brands are difference between bushes. The new ones that I've put in are Nolethane. and since i can't find any that suit the front inners, i was going to find some superpro to fit. can get them cheap enough.
So yea, would it matter being difference brands is what I'm asking?
Cheers
https://www.sau.com.au/forums/topic/367032-front-control-arm-bushes/
Cheers
The front left hand side on my r32 is creaking as well. The mechanic has diagnosed it to be the sway bar link and bushes and the D bushes that mount the sway bar. Let me know how you go fixing your problem. Where did you buy your bushes from?
only superpro makes the front inners
they are a little noisy at first but noise disappeared after a month or so, did a search and found out this happens to most people
it does seem like superpro bushes are a bit harder than others, so it will increase the harshness
but it did improve the front turn in a lot
Doesn't matter but some brands are better than others, and well...some are the same. How are they creaking? Do they just need some "lube action" or are they busted and have play?
I suppose they could just do with some lube,i thought i had packed a shiteload in when i put them in. its only a sometimes creak, normally after a long drive then coming into the driveway. like i said they were only replaced about a month of so ago. they were going good for about 3 weeks, then started creaking again.
I got the nolethane bushes from autobahn $140 from memory (front upper outer control arm)
Can get superpro from JDM obsession for $110 delivered for the inners (standard replacement)
Ah, cheer for the info
Edited by BstewyR33
  • 3 weeks later...
so the superpro front upper inner bushes are meant to make some creaking noise when you first put them in?
did you replace only the inner or both inner and outer?
I don't think they are meant to.. My guess is that they're harder than most others out there so that's why they are more prone to making noises.
They didnt at first for a couple of days and then they started getting noisy after that which lasted for 2 mths, then the noise went away
mine was squeaking . i changed the inner ones to the superpro ones and the noise reduced, but its still there.
now im thinking if its the outer bushes that are making the noises.
maybe i should try soapy water on the outer bushes and see if that helps.
when i said i dont think they're meant to, i meant it in a way where superpro didnt purposely make them to..
if properly greased then they shouldnt, but they do due to reasons such as formula/shape whatever reasons
mine has quietened down a lot
thing with rubber is when they're worn they dont really make any noise, but when they're worn they cause play in the arms which causes knocks, sometimes it may make squeaks because of metal rubbing on metal
yea i realised that..it could be that so happen they just seem to make a little bit of noise at first.
and also could be that it happens only in some cases..
my outer bushes look ok. not much play in them and theres no knocks, but i could be wrong.
they could look ok from the outside, but totally stuffed on the inside..
A spray with silicon spray is a good idea if they are already lubed. This can help to redistribute the lube.
If you don't have any please go and buy some as it works wonders for bush squeeks. Do not use WD40 or RP7 or anything with solvents, etc. Silicon spray is safe to use on rubber and urethane.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
    • Not required but appreciated. Super Coppermix Twin even the non-competition model feels like the pedal is noticeably heavier than stock which was pretty well judged IMO. I'll be swapping in the Nismo operating cylinder soon to see how that feels.  Personally I haven't felt anything that justifies replacing the damping loop, at least compared to more modern stuff where the clutch delay valve is actually quite noticeable.
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
