Hey guys, About a month or so again i replaced the upper outer control arm bushes on my R33 gtst. but i've noticed that the creaking sound is still there so i'm thinking it may be the inner bushes.
now it probably would have been a smart thing to replace those at the time i did the outer ones, but didn't think that far ahead.
my question is: does it matter if the brands are difference between bushes. The new ones that I've put in are Nolethane. and since i can't find any that suit the front inners, i was going to find some superpro to fit. can get them cheap enough.
So yea, would it matter being difference brands is what I'm asking?
Cheers
https://www.sau.com.au/forums/topic/367032-front-control-arm-bushes/
Cheers
The front left hand side on my r32 is creaking as well. The mechanic has diagnosed it to be the sway bar link and bushes and the D bushes that mount the sway bar. Let me know how you go fixing your problem. Where did you buy your bushes from?
only superpro makes the front inners
they are a little noisy at first but noise disappeared after a month or so, did a search and found out this happens to most people
it does seem like superpro bushes are a bit harder than others, so it will increase the harshness
but it did improve the front turn in a lot
Doesn't matter but some brands are better than others, and well...some are the same. How are they creaking? Do they just need some "lube action" or are they busted and have play?
I suppose they could just do with some lube,i thought i had packed a shiteload in when i put them in. its only a sometimes creak, normally after a long drive then coming into the driveway. like i said they were only replaced about a month of so ago. they were going good for about 3 weeks, then started creaking again.
I got the nolethane bushes from autobahn $140 from memory (front upper outer control arm)
Can get superpro from JDM obsession for $110 delivered for the inners (standard replacement)
Ah, cheer for the info
Edited by BstewyR33
  • 3 weeks later...
so the superpro front upper inner bushes are meant to make some creaking noise when you first put them in?
did you replace only the inner or both inner and outer?
I don't think they are meant to.. My guess is that they're harder than most others out there so that's why they are more prone to making noises.
They didnt at first for a couple of days and then they started getting noisy after that which lasted for 2 mths, then the noise went away
mine was squeaking . i changed the inner ones to the superpro ones and the noise reduced, but its still there.
now im thinking if its the outer bushes that are making the noises.
maybe i should try soapy water on the outer bushes and see if that helps.
when i said i dont think they're meant to, i meant it in a way where superpro didnt purposely make them to..
if properly greased then they shouldnt, but they do due to reasons such as formula/shape whatever reasons
mine has quietened down a lot
thing with rubber is when they're worn they dont really make any noise, but when they're worn they cause play in the arms which causes knocks, sometimes it may make squeaks because of metal rubbing on metal
yea i realised that..it could be that so happen they just seem to make a little bit of noise at first.
and also could be that it happens only in some cases..
my outer bushes look ok. not much play in them and theres no knocks, but i could be wrong.
they could look ok from the outside, but totally stuffed on the inside..
A spray with silicon spray is a good idea if they are already lubed. This can help to redistribute the lube.
If you don't have any please go and buy some as it works wonders for bush squeeks. Do not use WD40 or RP7 or anything with solvents, etc. Silicon spray is safe to use on rubber and urethane.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
