hi
i need your help
i sent my car in to a work shop to get my timing belt replaced over a months ago and also to get a greddy intake plenum done
the job was dont and they told me they needed to play with the tps settings on my ems 6860 and since them not been able to turn the car over
even with the base map
it waill turn and allmost start but just wont kick over
please help
https://www.sau.com.au/forums/topic/367051-ems-ecu-6860-help-car-wont-start/
ah ok thanks
thanks for the fast replys
its just been sitting in there now and being in wa there not much places i can take it too
they told me the car was starting at first but lumpy but now after playing with tps nothing
iv been there and put stock tune on it but no luck still
keeps turning and drains battery very quick
i have pluged to two at one to stop this
please not has stroker and after market injectors and turbo if that makes a diff
Bro I've got a stinger. I know all the EMS ecus have a clear flooded function, so when the tps senses 100% it wouldn't fire.
Is the tps set up properly? The signal could be negative?
Try disconnecting the tps? take a print screen of your ecu settings and fuel map and post it here! Il have a look compared to mine...
Edited by StealthX
i sent my car in to a work shop to get my timing belt replaced ... and since them not been able to turn the car over
... it waill turn and allmost start but just wont kick over
Check that the cams haven't moved during belt reinstall process. One tooth out on the timing gears will make a massive difference.
Surely the workshop that performed the work is looking to correct it? If so what is their diagnosis and fault finding plan?
problem solved
when they played with the tps settings some how the ignition point was set to 1 not 6
as the stock ecu uses 1 ignition point (the black box on your coil line )
its running lumpy now but they got fuel injection (ems) on the phone Friday to get it running good
thank you for all your help
and special thanks to Room42 for the personal help
Edited by r33pmysta
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
