I bought this peice of awesomeness:
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=339151
mainly for the engine
so anyway the rest of it I dont need so flick us a pm and i'll see if i can hook you up.
Pick up preferred, but also happy to post at your expense.
Parts that I can think of off the top of my head:
Rb25det manual conversion $1250 includes everything
5 stud conversion front and rear $950
Front $200 and rear $150 R32 Gtst brakes
X Force 3 inch exhaust $150 including large cat
HKS adjustable suspension $700 good condition
Locked rear diff $300
Immitation Bride drivers seat $300 (includes rail, in as new condition)
Alloy M-spec radiator $120
Stock radiator $80 perfect condition
Brake master $100
Koya 18 inch rims (5 stud) with new rubber $850
Shell $1500- In very good condition and previously registered in QLD. Includes URAS body kit.
Interior stuff- let me know what you want and make an offer.
I shall post up some more pics on the weekend when it's not dark and cold outside!
Happy to sell parts off the shell as well but obviously prefer to shift the entire shell altogether.
Parts located in lower Blue Mountains Sydney.
Pete
0448468884
https://www.sau.com.au/forums/topic/367053-wrecking-a31-cefiro/
Shell is sold!
Still available:
-5 stud
-front pipes
-headlights
-indicators
-diff
-Engine- 26/30
-intercooler kit
-JVC amp and sub
-Koya rims
-Centre console
-manual conversion excluding gearbox
Items sold:
-Whole shell
-Centre console and arm rest (car came with two!)
-gearbox
-exhaust
-body kit
-brakes
-suspensin
-seat
Adding pics of the left over parts... These have gotta go!
Intercooler $200
Engine: Rb26/30 $4,000
rebuilt stock bottom end, intake, exhaust steel wheel turbos, new timing belt, rwd sump, new gaskets etc
5 stud hubs $800
Headlights $200 pair
one has a broken part but they fit to the car fine:
Indicators $60 pair
Centre console $80
Complete boot trim $100
Koya Inox Drifter 18 inch rims, as new $700
Include Maxxis MA-V1 rubber with around 90% tread
18 x 8 +35 offset
JVC 600 watt 2 channel amp $40
11.5 inch sub $30 pick up only
Also still have:
- Locked diff $300
- air con set up $150
- manual conversion less the gearbox $150
Happy to post if required
Parts in lower Blue Mountains Sydney
Pete
0448468884
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
