For sale is the engine, ecu and exhaust from my R34 GTR V spec.
Perfect package for your R34 GTR, bolt in, drive away.
The engine is still running in the car and available for inspection, comp test and or test drive etc.
The reason for the sale is an RB30/26 transplant.
All items for sale are in excellent working condition.
WHAT IS FOR SALE?
The complete engine from the inlet plenum cold side to the turbos, dumps and complete exhaust system hot side, ecu included.
Only thing not included is the front Diff but both front and rear diffs are also available at extra cost.
ENGINE
R34 gtr RB 26
Forged bottom end
N1 oil pump
HKS adjustable cam gears
Greddy clear cam cover
Gates racing timing belt
750cc Sards
JJR coils
Apexi super suction kit
Z32 AFM's
Apexi pod filters
Garrett 2860-7 turbo's
Custom polished Catch can and washer bottle
Tuned by Godzilla Motorsports to 298kw@ 17 psi
Engine travelled 18000 klms since rebuild.
Oil changed every 3000 klms
ECU
Apexi Power FC with hand controller
EXHAUST
CES competition version split ceramic coated dumps 2000 deg
Custom ceramic coated y-pipe is twin 3in finishing at 3.5in collector
High flow cat
3in to rear Fujitsubo polished stainless muffler with 5in outlet
Do the math, it is worth more than twice this amount.
Will seperate engine, exhaust, and ecu if required.
I am located in Brisbane Southside.
I am a Mature car enthusiast who has fastediously maintained this engine.
Lowballers dont waste my or your time
Priced for quick sale.
Ross 0418 416 921
post-45687-0-46024300-1307521521_thumb.jpgpost-45687-0-09388900-1307521489_thumb.jpgpost-45687-0-20608100-1307521504_thumb.jpgpost-45687-0-21130800-1307521469_thumb.jpgpost-45687-0-91430300-1307521438_thumb.jpgpost-45687-0-51793700-1307521412_thumb.jpgpost-45687-0-98670800-1307521548_thumb.jpg
Depends on what you want?
Turbos? AFM? Apexi suction kit? filters? Inlet manifold?
Just call me to discuss any details if you are interested.
hang on while i try and sell a kidney on ebay. how much for the engine without the exhaust or ecu??
Bit of a tire kick here, so feel free not to answer (it may be helpful for other more serious people) How hard would this be to put into a GT-T and retain the RWD configuration?
Are the bellhousings on each box (GT-T and GTR) the same, so it would just match up?
Would the sump clear the cross member?
Would it be a matter of plugging in the ECU and just turning the key, or is the GT-T harness completely different and the pins do completely different things?
There has been the odd 34 going for around $13k at the moment, if I managed to pick one up at this price, and the effort to put this set up into it wasn't monumental, I'd definitely do it.
Again, feel free not to answer, because at this point in time, I'm not a genuine buyer, I am genuinely curious, however.
mind asking whats the reason for sale and how long the engine been running since rebuild ? thanks.
As the post says Im installing a RIPS rb 30/26. It was rebuilt 18000 klms ago, 2.5 yrs.
    • Gotcha, I mean that is at least good to hear. Are there signs, or troubleshooting tips to make sure the transmission is operating properly?
    • Well thats probably not gonna happen right away. LOL
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
