Hey All,
Wrecking 32 gtst in white has had hit in passanger door and no motor or gearbox.
So let me know what you need and i can post it to you. Pick up ok too.
Car is at Syndey concord 2137
Bit of a parts list:
  • Bonnet good con $100
  • guards good con
  • boot lid (no wing has holes) $70
  • front bar average
  • rear bar average con (scracted paint no reverse lights) $20
  • drivers door with door card $150
  • drivers mirror $50
  • projector headlights good con
  • tails light good con $70
  • Fuel flap FREEEEEEEEEEE
  • driver window $50
  • rear skirts like gtr i think.
  • center consol $40
  • driver seat $50
  • FRONT Brakes $250
  • REAR brakes
  • DIFF and rear subframe $350
  • Adjusable castor rods $50
  • Tail Shaft $70
  • Dash Cluster $125
And any other bit of thing you need. There to much to list.
please just msg me on 0415 292 220 as its the quickest way to get an answer .
parts left:
  • guards good con
  • front bar average
  • driver window $50
  • center consol $40
  • driver seat $50
  • FRONT Brakes $250
  • REAR brakes
  • Tail Shaft $70
  • Dash Cluster now only $50
REMEMBER THERE IS STILL ALOT OF BITS ON THE CAR.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
