i have a ls1 v8 auto commodore tow car.
its awesome.
it handles a big load no worries, you often forget your even towing sometimes!!!
i get 14.8 litres per 100 which isnt bad.
just needs some stiffer springs in the back as it tends to drag its arse a bit with a skyline behind it on the trailer.
i would recommend it as a tow car of choice to anyone. i would not recommend the xr6 turbo as the thing would be on boost all the time because of the load im figuring hence big fuel consumption.
Also just like to mention that I had a 2001 AU Falcon up until recently, and it was rubbish, terribly unreliable there was always something wrong with it, but in saying that it could have just been a lemon.
Must have been your car... Mine is reliable as anything and I've put over 50,000 km on it in the last year and a half.
Got a mate who got given his grandparents AU Fairmont after they towed a caravan around australia, and owning it for about 8 years of daily driving before the trip. he got it at 350k's, almost up to 400 now with just basic servicing and still going strong.
Yeah, I'd go the Ford. Neither are v8, but up until recently I had a VT daily, had problem after problem until I got rid of it for the Stagea. Meanwhile my parents have an AU similar age, far more km's, they go away lots, barely ever gets serviced close to on time, and has never missed a beat. Both are boats, but the AU has a lot more torque and a lot nicer to drive.
Not that it makes a difference, but it probably has the VCT tickford engine, being a fairmont.
Buy a Ford. you won't regret it. their engine last forever. why do you think most taxi's are all fords and not holden.
Yeah... but they are running on gas...
which has more problems comes down to who you speak too. generally speaking they both have a few faults, but will generally be hassle free. i've put about 10,000kms on my VT since march and here is a list off all the work i've had to do to it,
crytical stuff:
-new leads and plugs (did that last week as the old leads were friggin old, possibly the originals, and arcing out. $65, which craps all over the cost of new coils for a skyline, LOL)
-regassed the aircon and new dryer reciever (was original and only had 80% gas in it which was just enough that the aircon wouldn't cool. did this just after buying it and has been fine since)
-new o2 sensors. 1 was just starting to play up. (again, possibly the original items. and also changed for the sake of fuel economy.)
-new indicator stalk (relay inside was starting to tick and was driving me bonkers, new one cost about $20 on ebay)
non-crytical stuff:
-some dash bulbs
-standard springs (was lowered, had typical commodore camber issue and was cheaper than a camber kit)
-new fuel filter (did it just after i bought it for peace of mind)
-new thermostat (as above, done just after buying it for peace of mind since i drive nearly 65kms to work everyday)
i've also owned a falcon and had very little issues other than 2 head gaskets, but it was an EA so that says it all. owned a VX a few years back and it was also pretty reliable. only issue i ever had with it was the aircon compressor got a slight rattle to it (started after a bit of limiter bashing doing a burnout in a mates shed, LOL)
Most AU Fairmont's I looked at did not have a VCT engine...
Maybe your thinking of the fairlane?
  • 3 weeks later...
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
